Bu sürüm, hatalı düzenlemeler içerebilir. En son doğrulanmış bellek kopyası dönün.
Neye ihtiyacın var
Bu adım çevrilmemiş. Çevrilmesine yardım edin
Turn the phone off.
Flip it over so the front screen is facing down.
Slide the release latch down and toward you while lifting up on the left side of the battery cover.
Locate the three screw covers on the back of the phone. Using your fingernail (or a spudger, pry off screw covers.
Using a Phillips #000 Screwdriver, remove the 1.5mm #000 Phillips screws that were under the screw covers.
Locate the two inner 1.5mm #000 Phillips screws and remove them using a Phillips #000 screwdriver.
Use a plastic opening tool or your fingernail to pry off the back case.
