Ana içeriğe geç
LG Enact Charging Port Replacement
Neye ihtiyacın var
  1. LG Enact Charging Port Replacement, Battery: adım 1, 3 resimden 1. LG Enact Charging Port Replacement, Battery: adım 1, 3 resimden 2. LG Enact Charging Port Replacement, Battery: adım 1, 3 resimden 3.
    • Open the back cover by prying into the bottom tab with an iFixit opening tool.
  2. LG Enact Charging Port Replacement: adım 2, 3 resimden 1. LG Enact Charging Port Replacement: adım 2, 3 resimden 2. LG Enact Charging Port Replacement: adım 2, 3 resimden 3.
    • Use an iFixit opening tool to remove the battery.
  3. LG Enact Charging Port Replacement, Speaker: adım 3, 1 resimden 1.
    • Remove the three 1.2 mm screws from the speaker using a Phillips #00 screwdriver.
  4. LG Enact Charging Port Replacement: adım 4, 2 resimden 1. LG Enact Charging Port Replacement: adım 4, 2 resimden 2.
    • Use an iFixit opening pick to pop out the speaker.
  5. LG Enact Charging Port Replacement, Midframe: adım 5, 2 resimden 1. LG Enact Charging Port Replacement, Midframe: adım 5, 2 resimden 2.
    • Remove the nine 1.2 mm screws from the midframe using a Phillips #00 screwdriver.
  6. LG Enact Charging Port Replacement: adım 6, 1 resimden 1.
    • Use the iFixit opening pick to pry out the midframe.
  7. LG Enact Charging Port Replacement, Motherboard: adım 7, 2 resimden 1. LG Enact Charging Port Replacement, Motherboard: adım 7, 2 resimden 2.
    • Unplug the four ports connected to the motherboard.
    • Disconnect the two wires on top of the battery.
    • Disconnect the two wires under the battery.
  8. LG Enact Charging Port Replacement: adım 8, 2 resimden 1. LG Enact Charging Port Replacement: adım 8, 2 resimden 2.
    • Slowly pry out the motherboard using an iFixit opening pick.
  9. LG Enact Charging Port Replacement, Charging Port: adım 9, 2 resimden 1. LG Enact Charging Port Replacement, Charging Port: adım 9, 2 resimden 2.
    • Gently peel off the orange strip attached to the charging port using an iFixit opening pick.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 5
Her zaman: 70
