Ana içeriğe geç
LG Enact Screen Replacement
Neye ihtiyacın var
  1. LG Enact Screen Replacement, Battery: adım 1, 3 resimden 1. LG Enact Screen Replacement, Battery: adım 1, 3 resimden 2. LG Enact Screen Replacement, Battery: adım 1, 3 resimden 3.
    • Open the back cover by prying into the bottom tab with an iFixit opening tool.
  2. LG Enact Screen Replacement: adım 2, 3 resimden 1. LG Enact Screen Replacement: adım 2, 3 resimden 2. LG Enact Screen Replacement: adım 2, 3 resimden 3.
    • Use an iFixit opening tool to remove the battery.
  3. LG Enact Screen Replacement, Speaker: adım 3, 1 resimden 1.
    • Remove the three 1.2 mm screws from the speaker using a Phillips #00 screwdriver.
  4. LG Enact Screen Replacement: adım 4, 2 resimden 1. LG Enact Screen Replacement: adım 4, 2 resimden 2.
    • Use an iFixit opening pick to pop out the speaker.
  5. LG Enact Screen Replacement, Midframe: adım 5, 2 resimden 1. LG Enact Screen Replacement, Midframe: adım 5, 2 resimden 2.
    • Remove the nine 1.2 mm screws from the midframe using a Phillips #00 screwdriver.
  6. LG Enact Screen Replacement: adım 6, 1 resimden 1.
    • Use the iFixit opening pick to pry out the midframe.
  7. LG Enact Screen Replacement, Motherboard: adım 7, 2 resimden 1. LG Enact Screen Replacement, Motherboard: adım 7, 2 resimden 2.
    • Unplug the four ports connected to the motherboard.
    • Disconnect the two wires on top of the battery.
    • Disconnect the two wires under the battery.
  8. LG Enact Screen Replacement: adım 8, 2 resimden 1. LG Enact Screen Replacement: adım 8, 2 resimden 2.
    • Slowly pry out the motherboard using an iFixit opening pick.
  9. LG Enact Screen Replacement, Charging Port: adım 9, 2 resimden 1. LG Enact Screen Replacement, Charging Port: adım 9, 2 resimden 2.
    • Gently peel off the orange strip attached to the charging port using an iFixit opening pick.
  10. LG Enact Screen Replacement, Keyboard: adım 10, 3 resimden 1. LG Enact Screen Replacement, Keyboard: adım 10, 3 resimden 2. LG Enact Screen Replacement, Keyboard: adım 10, 3 resimden 3.
    • Gently remove the blue metal plate using an iFixit opening pick.
    • Gently remove the black plastic from inside the battery compartment.
  11. LG Enact Screen Replacement: adım 11, 1 resimden 1.
    • Remove seven 1.2 mm screws with a Phillips #00 screwdriver.
  12. LG Enact Screen Replacement: adım 12, 1 resimden 1.
    • Remove the ribbon cable from the battery compartment.
  13. LG Enact Screen Replacement: adım 13, 3 resimden 1. LG Enact Screen Replacement: adım 13, 3 resimden 2. LG Enact Screen Replacement: adım 13, 3 resimden 3.
    • Remove the plastic half containing the keyboard.
  14. LG Enact Screen Replacement, Screen: adım 14, 1 resimden 1.
    • Remove the four 1.2 mm screws from the corners using a Phillips #00 screwdriver.
  15. LG Enact Screen Replacement: adım 15, 2 resimden 1. LG Enact Screen Replacement: adım 15, 2 resimden 2.
    • Gently pry the screen open with a nylon spudger, making sure you’re not damaging the LCD or the plastic.
  16. LG Enact Screen Replacement: adım 16, 2 resimden 1. LG Enact Screen Replacement: adım 16, 2 resimden 2.
    • Detach the two connectors from the screen and pop the screen open using a spudger.
  17. LG Enact Screen Replacement: adım 17, 1 resimden 1.
    • Disconnect the touch button sensors using a spudger.
  18. LG Enact Screen Replacement: adım 18, 1 resimden 1.
    • Gently disconnect and remove the LCD using a spudger.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 6
Her zaman: 79
