Ana içeriğe geç
LG Encore GT550 Audio Jack Replacement
Neye ihtiyacın var
  1. LG Encore GT550 Audio Jack Replacement, Audio Jack: adım 1, 2 resimden 1. LG Encore GT550 Audio Jack Replacement, Audio Jack: adım 1, 2 resimden 2.
    • Turn the device over so the backside is facing up.
    • Use your fingers or an opening tool to remove the back cover in order to expose the battery.
  2. LG Encore GT550 Audio Jack Replacement: adım 2, 2 resimden 1. LG Encore GT550 Audio Jack Replacement: adım 2, 2 resimden 2.
    • Use your fingers or a spudger to remove the battery. Lift it from the side opposite of the camera.
  3. LG Encore GT550 Audio Jack Replacement: adım 3, 1 resimden 1.
    • Use a Phillips #0 screwdriver to remove six screws around the perimeter of the phone.
  4. LG Encore GT550 Audio Jack Replacement: adım 4, 2 resimden 1. LG Encore GT550 Audio Jack Replacement: adım 4, 2 resimden 2.
    • Place the opening tool in the seam of the device and pry around the perimeter to separate the top case from the bottom case.
  5. LG Encore GT550 Audio Jack Replacement: adım 5, 2 resimden 1. LG Encore GT550 Audio Jack Replacement: adım 5, 2 resimden 2.
    • Place the opening tool on the top on the device between the phone casing and motherboard.
    • Separate the screen and the motherboard.
  6. LG Encore GT550 Audio Jack Replacement: adım 6, 1 resimden 1.
    • Push the audio jack out and replace it.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Lindsey Harding
501 İtibar
5 adet Kılavuz yazıldı
Ekip
UMass Dartmouth, Team 1-4, Shastany Fall 2013 UMass Dartmouth, Team 1-4, Shastany Fall 2013 üyesi
UMASSD-SHASTANY-F13S1G4
2 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 1
Her zaman: 212
