Ana içeriğe geç
LG Escape (p870) Loudspeaker Assembly Replacement
Neye ihtiyacın var
  1. LG Escape (p870) Loudspeaker Assembly Replacement, Battery: adım 1, 2 resimden 1. LG Escape (p870) Loudspeaker Assembly Replacement, Battery: adım 1, 2 resimden 2.
    • Turn the device over and pull the back plastic cover off by inserting your fingernail into the opening at the bottom of the phone and gently pulling.
  2. LG Escape (p870) Loudspeaker Assembly Replacement: adım 2, 2 resimden 1. LG Escape (p870) Loudspeaker Assembly Replacement: adım 2, 2 resimden 2.
    • With your finger and from the bottom edge, lift the battery out of the phone and set it aside.
    • You now have access to:
    • Your SD card
    • Your SIM card
    • Your device's serial numbers
  3. LG Escape (p870) Loudspeaker Assembly Replacement, Loudspeaker Assembly: adım 3, 1 resimden 1.
    • Remove the 4 Phillips 00 screws securing the speaker assembly to the phone housing.
  4. LG Escape (p870) Loudspeaker Assembly Replacement: adım 4, 2 resimden 1. LG Escape (p870) Loudspeaker Assembly Replacement: adım 4, 2 resimden 2.
    • Carefully insert a small flathead screwdriver between the speaker assembly and the rear housing
    • Pry the speaker assembly out of the phone and set it aside
Sonuç
Bir başkası bu kılavuzu tamamladı.
Brad
1.908 İtibar
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 305
