Giriş
This guide will show your how to replace the rear camera in your LG Escape (p870).
Neye ihtiyacın var
Turn the device over and pull the back plastic cover off by inserting your fingernail into the opening at the bottom of the phone and gently pulling.
Remove the 4 Phillips 00 screws securing the speaker assembly to the phone housing.
Remove the remaining 6 screws securing the plastic frame to the back housing
Insert a black plastic spudger or a small flathead screwdriver between the back silver bezel and the black area and begin prying the bezel away from the rest of the phone
Continue working your way around the phone, prying carefully with your prying tool
When you work the frame free, set it aside
