Giriş
This is how to replace the battery in the 2011 LG Extravert.
Neye ihtiyacın var
Remove the case on the back of the cell phone by pulling up on the little indent with your fingernail or a Spudger in the bottom of the phone.
After you pull off the case, the battery is right under it. All you have to do is put you Spudger or fingernail into the indent on the right side of the battery and pull up.
Bir başkası bu kılavuzu tamamladı.
