Ana içeriğe geç
LG Flare Microphone Replacement
Neye ihtiyacın var
  1. LG Flare Microphone Replacement, Microphone: adım 1, 2 resimden 1. LG Flare Microphone Replacement, Microphone: adım 1, 2 resimden 2.
    • Remove the back cover by pressing on the top middle raised lines of the back cover and sliding the cover off.
  2. LG Flare Microphone Replacement: adım 2, 1 resimden 1.
    • Remove the battery by popping the top out and removing the battery.
  3. LG Flare Microphone Replacement: adım 3, 1 resimden 1.
    • Use appropriately sized Philips-head screwdriver to remove the six small screws on the back of the phone under the battery.
  4. LG Flare Microphone Replacement: adım 4, 1 resimden 1.
    • Use an opening tool to pop the back panel apart around the edges, and then pry the whole piece off.
  5. LG Flare Microphone Replacement: adım 5, 1 resimden 1.
    • Use an opening tool to separate the tabs on the green circuit board from the front body of the phone.
  6. LG Flare Microphone Replacement: adım 6, 1 resimden 1.
    • Use an opening tool to pop the orange connecting strip off of the circuit board.
  7. LG Flare Microphone Replacement: adım 7, 1 resimden 1.
    • Un-clip the 2 metal clips on one side of the circuit board.
  8. LG Flare Microphone Replacement: adım 8, 2 resimden 1. LG Flare Microphone Replacement: adım 8, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Using tweezers and wedge, remove silver piece from green circuit board.
  9. LG Flare Microphone Replacement: adım 9, 1 resimden 1.
    • Remove the microphone (rip soldering).
  10. LG Flare Microphone Replacement: adım 10, 1 resimden 1.
    • Solder new microphone in place OR buy replacement circuit board from www.ifixit.com and replace.
Sonuç
Kelsey Hanna
1 İtibar
1 Kılavuz yazıldı
Ekip
Ohio State, Team 1-3, Garvin Fall 2015 Ohio State, Team 1-3, Garvin Fall 2015 üyesi
OSU-GARVIN-F15S1G3
4 Üyeler
4 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 6
Her zaman: 195
