Ana içeriğe geç
LG Fortune Speaker Replacement
Neye ihtiyacın var
  1. LG Fortune Speaker Replacement, Battery: adım 1, 2 resimden 1. LG Fortune Speaker Replacement, Battery: adım 1, 2 resimden 2.
    • Use the slit on the bottom right side of the phone to open the back cover of your phone.
    • It will be the bottom left of the phone if looking at it from the back.
    • Slowly pry the back cover off the phone starting from the bottom up to the top.
    FixBot'a Sor
    Yorum Ekle
  2. LG Fortune Speaker Replacement: adım 2, 2 resimden 1. LG Fortune Speaker Replacement: adım 2, 2 resimden 2.
    • Use the slot in the middle of the bottom edge of the battery to pry it up and out of the case.
    FixBot'a Sor
    Yorum Ekle
  3. LG Fortune Speaker Replacement, Speaker: adım 3, 2 resimden 1. LG Fortune Speaker Replacement, Speaker: adım 3, 2 resimden 2.
    • Use your PH000 screwdriver to remove the ten 1.4mm x 4mm screws.
    FixBot'a Sor
    Yorum Ekle
  4. LG Fortune Speaker Replacement: adım 4, 1 resimden 1.
    • Remove the paneling on the bottom left side of the device.
    • This is done by grabbing it on the left side where it should be a little loose and easily come off.
    FixBot'a Sor
    Yorum Ekle
  5. LG Fortune Speaker Replacement: adım 5, 2 resimden 1. LG Fortune Speaker Replacement: adım 5, 2 resimden 2.
    • Use either a spudger or your finger to separate the back of the device from the screen.
    • Using a metal spudger as shown in the photos has the potential to damage your device.
    • You will wedge your item on the upper right hand corner of the device to separate them. The speaker will be on the side of the device not connected to the screen.
    FixBot'a Sor
    Yorum Ekle
  6. LG Fortune Speaker Replacement: adım 6, 3 resimden 1. LG Fortune Speaker Replacement: adım 6, 3 resimden 2. LG Fortune Speaker Replacement: adım 6, 3 resimden 3.
    • Using the metal spudger lift up and remove the speaker along with the magnetic tape it comes with.
    FixBot'a Sor
    Yorum Ekle
Sonuç
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 6
Son 30 gün: 23
Her zaman: 937
