Ana içeriğe geç
LG Front Load Washing Machine Pump Hose Replacement
Neye ihtiyacın var
    1. LG Front Load Washing Machine Pump Hose Replacement, Safety Precautions: adım 1, 2 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Safety Precautions: adım 1, 2 resimden 2.
      • Before you begin your repair, perform the following:
      • Turn off the main water supply
      • Unplug your washer
      • Disconnect all water connections at the rear of your washer
      FixBot'a Sor
      Yorum Ekle
    1. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the top panel: adım 2, 3 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the top panel: adım 2, 3 resimden 2. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the top panel: adım 2, 3 resimden 3.
      • Remove the screw(s) securing the top panel brackets to the back panel.
      • You don't need to remove the screws securing the brackets to the top panel.
      FixBot'a Sor
      Yorum Ekle
    2. LG Front Load Washing Machine Pump Hose Replacement, Remove the top panel: adım 3, 2 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Remove the top panel: adım 3, 2 resimden 2.
      • Slide the top panel towards the rear of the device to disconnect its clips.
      FixBot'a Sor
      Yorum Ekle
    3. LG Front Load Washing Machine Pump Hose Replacement: adım 4, 2 resimden 1. LG Front Load Washing Machine Pump Hose Replacement: adım 4, 2 resimden 2.
      • Tilt the top panel upward to completely disconnect it from the chassis.
      • Remove the top panel.
      FixBot'a Sor
      Yorum Ekle
    1. LG Front Load Washing Machine Pump Hose Replacement, Remove the detergent drawer: adım 5, 2 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Remove the detergent drawer: adım 5, 2 resimden 2.
      • Pull the detergent drawer away from the chassis as far as it will go.
      FixBot'a Sor
      Yorum Ekle
    2. LG Front Load Washing Machine Pump Hose Replacement: adım 6, 3 resimden 1. LG Front Load Washing Machine Pump Hose Replacement: adım 6, 3 resimden 2. LG Front Load Washing Machine Pump Hose Replacement: adım 6, 3 resimden 3.
      • Press down on the "Push" button to disengage the clips securing the detergent drawer.
      • Pull the drawer out of its slot on the chassis and remove it.
      FixBot'a Sor
      Yorum Ekle
    1. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the control panel: adım 7, 3 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the control panel: adım 7, 3 resimden 2. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the control panel: adım 7, 3 resimden 3.
      • Disconnect the connectors attached to the control panel.
      • Always grip cables by their connectors and not the wires themselves.
      FixBot'a Sor
      Yorum Ekle
    2. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the control panel: adım 8, 2 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the control panel: adım 8, 2 resimden 2.
      • Remove the screw(s) securing the control panel to the top edge of the chassis.
      FixBot'a Sor
      Yorum Ekle
    3. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the detergent dispenser: adım 9, 1 resimden 1.
      • Remove the screw(s) securing the detergent dispenser.
      FixBot'a Sor
      Yorum Ekle
    4. LG Front Load Washing Machine Pump Hose Replacement, Unclip the control panel: adım 10, 3 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Unclip the control panel: adım 10, 3 resimden 2. LG Front Load Washing Machine Pump Hose Replacement, Unclip the control panel: adım 10, 3 resimden 3.
      • Use a flathead screwdriver, or a pry tool, to unclip the control panel from the chassis.
      FixBot'a Sor
      Yorum Ekle
    5. LG Front Load Washing Machine Pump Hose Replacement, Remove the control panel: adım 11, 3 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Remove the control panel: adım 11, 3 resimden 2. LG Front Load Washing Machine Pump Hose Replacement, Remove the control panel: adım 11, 3 resimden 3.
      • Remove the control panel, making sure to thread any cables through the chassis.
      FixBot'a Sor
      Yorum Ekle
    1. LG Front Load Washing Machine Pump Hose Replacement, Open the door: adım 12, 2 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Open the door: adım 12, 2 resimden 2.
      • Open the front door completely.
      FixBot'a Sor
      Yorum Ekle
    2. LG Front Load Washing Machine Pump Hose Replacement, Remove the boot ring: adım 13, 3 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Remove the boot ring: adım 13, 3 resimden 2. LG Front Load Washing Machine Pump Hose Replacement, Remove the boot ring: adım 13, 3 resimden 3.
      • Use needle nose pliers to grip the spring end of the metal ring at the bottom of the rubber boot.
      • Pull the ring away from the chassis to separate it from the boot.
      FixBot'a Sor
      Yorum Ekle
    3. LG Front Load Washing Machine Pump Hose Replacement: adım 14, 3 resimden 1. LG Front Load Washing Machine Pump Hose Replacement: adım 14, 3 resimden 2. LG Front Load Washing Machine Pump Hose Replacement: adım 14, 3 resimden 3.
      • Use your hand to completely pull the ring off the boot.
      • During reassembly, perform the following:
      • Insert one end of the ring into its groove along the boot's perimeter.
      • Use pliers to slowly stretch the ring around the boot's perimeter until it's completely nested in its groove.
      • Be sure the spring is centered at the bottom of the boot when you reinstall it.
      • This procedure will take significant force.
      FixBot'a Sor
      Yorum Ekle
    4. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the boot: adım 15, 3 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the boot: adım 15, 3 resimden 2. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the boot: adım 15, 3 resimden 3.
      • Use your fingers to pull the boot off its lip on the front panel.
      FixBot'a Sor
      Yorum Ekle
    5. LG Front Load Washing Machine Pump Hose Replacement: adım 16, 3 resimden 1. LG Front Load Washing Machine Pump Hose Replacement: adım 16, 3 resimden 2. LG Front Load Washing Machine Pump Hose Replacement: adım 16, 3 resimden 3.
      • Slide your fingers around the lip of the boot until it's completely separated from the panel.
      FixBot'a Sor
      Yorum Ekle
    6. LG Front Load Washing Machine Pump Hose Replacement, Remove the filter panel: adım 17, 3 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Remove the filter panel: adım 17, 3 resimden 2. LG Front Load Washing Machine Pump Hose Replacement, Remove the filter panel: adım 17, 3 resimden 3.
      • Open the filter panel at the bottom of the front panel.
      • Unclip the filter panel.
      FixBot'a Sor
      Yorum Ekle
    7. LG Front Load Washing Machine Pump Hose Replacement, Drain the machine: adım 18, 3 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Drain the machine: adım 18, 3 resimden 2. LG Front Load Washing Machine Pump Hose Replacement, Drain the machine: adım 18, 3 resimden 3.
      • Generally, you should drain your machine when you are repairing the pumps or any hoses leading to or from them.
      • Place a bowl next to the machine.
      • Pull the drain filter hose out of its slot in the chassis enough to lay over the bowl.
      • Remove the plug at the end of the drain filter hose to release excess water into the bowl.
      • During reassembly, re-plug the drain filter hose and thread it back through its slot in the chassis.
      FixBot'a Sor
      Yorum Ekle
    8. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the filter trim: adım 19, 1 resimden 1.
      • Remove the screw(s) securing the filter trim.
      FixBot'a Sor
      Yorum Ekle
    9. LG Front Load Washing Machine Pump Hose Replacement, Remove the filter trim: adım 20, 2 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Remove the filter trim: adım 20, 2 resimden 2.
      • Pull the filter trim straight off the front panel to remove it.
      FixBot'a Sor
      Yorum Ekle
    10. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the lower front panel: adım 21, 1 resimden 1.
      • Remove the screw(s) securing the lower front panel.
      FixBot'a Sor
      Yorum Ekle
    11. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the door latch: adım 22, 1 resimden 1.
      • Remove the screw(s) securing the door latch.
      FixBot'a Sor
      Yorum Ekle
    12. LG Front Load Washing Machine Pump Hose Replacement, Remove the door latch: adım 23, 3 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Remove the door latch: adım 23, 3 resimden 2. LG Front Load Washing Machine Pump Hose Replacement, Remove the door latch: adım 23, 3 resimden 3.
      • Pull the door latch through its slot in the chassis and let it hang on its wire.
      FixBot'a Sor
      Yorum Ekle
    13. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the front panel: adım 24, 3 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the front panel: adım 24, 3 resimden 2. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the front panel: adım 24, 3 resimden 3.
      • Hold the front panel against the chassis while performing this step to prevent it from falling.
      • Remove the screw(s) securing the front panel.
      FixBot'a Sor
      Yorum Ekle
    14. LG Front Load Washing Machine Pump Hose Replacement, Remove the front panel: adım 25, 3 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Remove the front panel: adım 25, 3 resimden 2. LG Front Load Washing Machine Pump Hose Replacement, Remove the front panel: adım 25, 3 resimden 3.
      • Lift the front panel upward to separate it from its clips on the bottom of the chassis.
      • Pull the front panel away from the chassis to completely separate the front panel.
      FixBot'a Sor
      Yorum Ekle
    15. LG Front Load Washing Machine Pump Hose Replacement: adım 26, 1 resimden 1.
      • Remove the front panel.
      FixBot'a Sor
      Yorum Ekle
    1. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the tub to pump hose: adım 27, 3 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the tub to pump hose: adım 27, 3 resimden 2. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the tub to pump hose: adım 27, 3 resimden 3.
      • Use slip joint pliers to pinch the tub to pump hose clamp and pull it away from the assembly.
      • Pull the hose straight off the assembly to disconnect it.
      FixBot'a Sor
      Yorum Ekle
    1. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the rear panel: adım 28, 3 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the rear panel: adım 28, 3 resimden 2. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the rear panel: adım 28, 3 resimden 3.
      • Remove the screw(s) securing the rear panel.
      FixBot'a Sor
      Yorum Ekle
    2. LG Front Load Washing Machine Pump Hose Replacement, Remove the rear panel: adım 29, 3 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Remove the rear panel: adım 29, 3 resimden 2. LG Front Load Washing Machine Pump Hose Replacement, Remove the rear panel: adım 29, 3 resimden 3.
      • Unclip the rear panel from the chassis.
      FixBot'a Sor
      Yorum Ekle
    3. LG Front Load Washing Machine Pump Hose Replacement: adım 30, 1 resimden 1.
      • Remove the rear panel.
      FixBot'a Sor
      Yorum Ekle
    1. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the air dome: adım 31, 2 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the air dome: adım 31, 2 resimden 2.
      • Pull the hose straight off the air dome hose to disconnect it.
      FixBot'a Sor
      Yorum Ekle
    2. LG Front Load Washing Machine Pump Hose Replacement, Unfasten the air dome: adım 32, 1 resimden 1.
      • Remove the screw(s) securing the air dome.
      FixBot'a Sor
      Yorum Ekle
    3. LG Front Load Washing Machine Pump Hose Replacement: adım 33, 3 resimden 1. LG Front Load Washing Machine Pump Hose Replacement: adım 33, 3 resimden 2. LG Front Load Washing Machine Pump Hose Replacement: adım 33, 3 resimden 3.
      • Use slip joint pliers to pinch the air dome hose clamp and pull it over the dome itself.
      FixBot'a Sor
      Yorum Ekle
    4. LG Front Load Washing Machine Pump Hose Replacement, Remove the air dome: adım 34, 2 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Remove the air dome: adım 34, 2 resimden 2.
      • Pull the air dome straight off its hose to remove it.
      FixBot'a Sor
      Yorum Ekle
    1. LG Front Load Washing Machine Pump Hose Replacement, Loosen the pump hose: adım 35, 2 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Loosen the pump hose: adım 35, 2 resimden 2.
      • Use a Phillips driver to loosen the pump hose from the drum enough to disconnect it.
      FixBot'a Sor
      Yorum Ekle
    2. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the pump hose: adım 36, 2 resimden 1. LG Front Load Washing Machine Pump Hose Replacement, Disconnect the pump hose: adım 36, 2 resimden 2.
      • Pull the pump hose straight off the drum to disconnect it.
      FixBot'a Sor
      Yorum Ekle
    3. LG Front Load Washing Machine Pump Hose Replacement, Remove the pump hose: adım 37, 1 resimden 1.
      • Remove the pump hose.
      • During reassembly, use liquid laundry detergent to lubricate the hose around its tub connection.
      FixBot'a Sor
      Yorum Ekle
Sonuç
Bill Gilbert
40.177 İtibar
261 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
123 Üyeler
61.324 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 22
Son 30 gün: 102
Her zaman: 2,600
