Ana içeriğe geç
LG G Pad 10.1 Display Assembly Replacement
Neye ihtiyacın var
  1. LG G Pad 10.1 Display Assembly Replacement, Rear Case: adım 1, 1 resimden 1.
    • To remove the back panel of the device, start by attempting to fit the plastic opening tool in the crease between the screen and the back panel of the tablet.
    • Try opening picks if the case is not flexing enough, or if it is already cracked to prevent further damage.
    • You can use your hands to push against the corners of the device to attempt to make the gap larger for your plastic opening tool to fit in.
    • If you are replacing your screen because it is damaged, it may be useful to pick away at some of the glass to expose the clips in the edges of the plastic.
    • Insert the corners of your plastic opening tool into the slots that are on the very outside edge of your device to start disconnecting the panel.
    • On some models, there is a vertical strip of adhesive between the battery and the back cover on the left side of the Verizon logo. Be careful not to damage the battery when separating the adhesive!
    FixBot'a Sor
    Yorum Ekle
  2. LG G Pad 10.1 Display Assembly Replacement: adım 2, 1 resimden 1.
    • Once the edge of your device's panel is separate from the screen, continue moving around the outside of the device while continuing to pry the two pieces apart from each other.
    FixBot'a Sor
    Yorum Ekle
  3. LG G Pad 10.1 Display Assembly Replacement: adım 3, 1 resimden 1.
    • Insert another plastic opening tool (or a similar tool) between the screen and the back panel on the opposite side of the device to hold it open.
    FixBot'a Sor
    Yorum Ekle
  4. LG G Pad 10.1 Display Assembly Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery by inserting the point of a spudger underneath the white tabs on either side of the connector and gently pry up.
    FixBot'a Sor
    Yorum Ekle
  5. LG G Pad 10.1 Display Assembly Replacement, Display Assembly: adım 5, 1 resimden 1.
    • Locate the rectangular display cable connection near the speaker.
    • It may be covered by a piece of black tape.
    • Use the spudger to pry the clip to disconnect it.
    FixBot'a Sor
    Yorum Ekle
  6. LG G Pad 10.1 Display Assembly Replacement: adım 6, 3 resimden 1. LG G Pad 10.1 Display Assembly Replacement: adım 6, 3 resimden 2. LG G Pad 10.1 Display Assembly Replacement: adım 6, 3 resimden 3.
    • Use a hair dryer or heat gun to soften the adhesive holding the display assembly to the frame.
    • Heat one side of the device, then insert opening picks between the digitizer and the frame to separate the adhesive.
    • Heat one side of the device at a time to ensure that the adhesive stays soft.
    • If your screen is severely cracked, use a suction cup to pull the display assembly up.
    • Be careful to not bend the metal tabs in these areas.
    FixBot'a Sor
    Yorum Ekle
  7. LG G Pad 10.1 Display Assembly Replacement: adım 7, 1 resimden 1.
    • The display assembly is still attached with this electrically conductive tape.
    • If possible, start lifting the display assembly from the bottom to gradually peel it away from the tape.
    • Reapply heat as necessary if adhesive cools too much.
    FixBot'a Sor
    Yorum Ekle
  8. LG G Pad 10.1 Display Assembly Replacement: adım 8, 2 resimden 1. LG G Pad 10.1 Display Assembly Replacement: adım 8, 2 resimden 2.
    • Now that the screen has been removed, clean up the remaining glue and glass shards around the edges of the device.
    • Compare the new and old screens and transfer any missing pieces, such as these electrically conductive pads.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Apply Tesa tape to the frame and attach the replacement display assembly.
40 farklı kişi bu kılavuzu tamamladı.
Alex Roszkowski
2.333 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-1, Blackwell Fall 2015 USF Tampa, Team 15-1, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S15G1
4 Üyeler
12 adet Kılavuz yazıldı
7Kılavuz Yorumları
Is there a place where one can purchase the glass for this? And can one do the glass only repair on this like you can an iPad without any uv lights and glue?
mcaddie7 - Yanıt Paylaş
my lg 700 was dropped. the outer glass was cracked but i cant tell if i need the lcd screen also. the device doesn't respond to any screen commands at all, it just turns on and then the screen goes into the regular power save. does this mean i need an lcd too? or is it expected that the unit wont take any commands if the outer glass is cracked. my only comparison is an iphone 4 that was driven over with the glass completely shattered, but the apps still responded through the shattered glass. any ideas?
John Burns - Yanıt Paylaş
The full LCD assembly is required, the glass is LOCA to the LCD, parts are available on ebay.
neilorr89 - Yanıt Paylaş
What does it mean the glass is LOCA to the LCD? I ordered a replacement glass for mine without the LCD. My LCD seems to be fine. Is it necessary to complete this full removal or is there a way to just affix the glass to the LCD?
Mark MacLachlan - Yanıt Paylaş
Mark MacLachlan - LOCA is Liquid Optically Clear Adhesive - Here is more info: https://en.wikipedia.org/wiki/Liquid_opt...
Having just done this repair, it is nearly impossible, even with a heat plate, to separate the digitizer from the LCD without scratching or damaging the LCD, and the time alone is not worth it. Buy the LCD/Digitizer as one unit.
Scott Alcott - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 4
Son 30 gün: 47
Her zaman: 27,604
