Giriş
This guide will demonstrate how to remove the front display on the LG G Pad 10.1. Keep in mind that the front display should only be removed if you intend to replace it, so if that is not your goal please refer back to the troubleshooting page to rethink your process. Remember to not proceed with this guide unless you have a replacement screen ready, as these steps will potentially further damage your current screen.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
To remove the back panel of the device, start by attempting to fit the plastic opening tool in the crease between the screen and the back panel of the tablet.
Try opening picks if the case is not flexing enough, or if it is already cracked to prevent further damage.
You can use your hands to push against the corners of the device to attempt to make the gap larger for your plastic opening tool to fit in.
If you are replacing your screen because it is damaged, it may be useful to pick away at some of the glass to expose the clips in the edges of the plastic.
Insert the corners of your plastic opening tool into the slots that are on the very outside edge of your device to start disconnecting the panel.
Locate the rectangular display cable connection near the speaker.
Use the spudger to pry the clip to disconnect it.
Use a hair dryer or heat gun to soften the adhesive holding the display assembly to the frame.
Heat one side of the device, then insert opening picks between the digitizer and the frame to separate the adhesive.
Heat one side of the device at a time to ensure that the adhesive stays soft.
If your screen is severely cracked, use a suction cup to pull the display assembly up.
Be careful to not bend the metal tabs in these areas.
Apply Tesa tape to the frame and attach the replacement display assembly.
40 farklı kişi bu kılavuzu tamamladı.
7 Yorum
my lg 700 was dropped. the outer glass was cracked but i cant tell if i need the lcd screen also. the device doesn't respond to any screen commands at all, it just turns on and then the screen goes into the regular power save. does this mean i need an lcd too? or is it expected that the unit wont take any commands if the outer glass is cracked. my only comparison is an iphone 4 that was driven over with the glass completely shattered, but the apps still responded through the shattered glass. any ideas?
What does it mean the glass is LOCA to the LCD? I ordered a replacement glass for mine without the LCD. My LCD seems to be fine. Is it necessary to complete this full removal or is there a way to just affix the glass to the LCD?
Mark MacLachlan - LOCA is Liquid Optically Clear Adhesive - Here is more info: https://en.wikipedia.org/wiki/Liquid_opt...
Having just done this repair, it is nearly impossible, even with a heat plate, to separate the digitizer from the LCD without scratching or damaging the LCD, and the time alone is not worth it. Buy the LCD/Digitizer as one unit.
I have this model of LG V700, rain mistakenly wet me with it. so its not powering up but when i connect with the computer it can read memory on the board and even the memory card attached to it. so i’m thinking its screen problem. is there there away to clean the the screen and touch flex maybe they are rusted. I’m very sure the board is ok because its connect on the computer only that its not showing up on the tablet screen.
I have a Lg v700, it will boot but will not charge, the glass is cracked in two places and it indicated over heat, I believe the its over heating due to the load since the screen is cracked. i charged it up to 40% about 4 days ago and it would not go higher and this is when the over load message or heat of the processor in danger.
My plan is to replace the lcd screen in hopes it will fix itself, yes or no?
