Ana içeriğe geç
LG G Pad 10.1 Speaker Replacement
Neye ihtiyacın var
  1. LG G Pad 10.1 Speaker Replacement, Rear Case: adım 1, 1 resimden 1.
    • To remove the back panel of the device, start by attempting to fit the plastic opening tool in the crease between the screen and the back panel of the tablet.
    • Try opening picks if the case is not flexing enough, or if it is already cracked to prevent further damage.
    • You can use your hands to push against the corners of the device to attempt to make the gap larger for your plastic opening tool to fit in.
    • If you are replacing your screen because it is damaged, it may be useful to pick away at some of the glass to expose the clips in the edges of the plastic.
    • Insert the corners of your plastic opening tool into the slots that are on the very outside edge of your device to start disconnecting the panel.
    • On some models, there is a vertical strip of adhesive between the battery and the back cover on the left side of the Verizon logo. Be careful not to damage the battery when separating the adhesive!
  2. LG G Pad 10.1 Speaker Replacement: adım 2, 1 resimden 1.
    • Once the edge of your device's panel is separate from the screen, continue moving around the outside of the device while continuing to pry the two pieces apart from each other.
  3. LG G Pad 10.1 Speaker Replacement: adım 3, 1 resimden 1.
    • Insert another plastic opening tool (or a similar tool) between the screen and the back panel on the opposite side of the device to hold it open.
  4. LG G Pad 10.1 Speaker Replacement: adım 4, 1 resimden 1.
    • Disconnect the battery by inserting the point of a spudger underneath the white tabs on either side of the connector and gently pry up.
  5. LG G Pad 10.1 Speaker Replacement, Motherboard: adım 5, 1 resimden 1.
    • Remove the five 2 mm Phillips #000 screws securing the motherboard.
    • The silver EMI shield may come off during this step. Just set it aside until reassembly.
  6. LG G Pad 10.1 Speaker Replacement: adım 6, 1 resimden 1.
    • Remove the two 5 mm Phillips #000 securing the motherboard,
  7. LG G Pad 10.1 Speaker Replacement: adım 7, 1 resimden 1.
    • Disconnect the cable from the battery to the motherboard by grabbing the cable and pulling upwards.
  8. LG G Pad 10.1 Speaker Replacement: adım 8, 2 resimden 1. LG G Pad 10.1 Speaker Replacement: adım 8, 2 resimden 2.
    • Using the spudger, pry up the connector on the motherboard from the back camera to disconnect it.
  9. LG G Pad 10.1 Speaker Replacement: adım 9, 1 resimden 1.
    • Then move to the front camera towards the end of the motherboard and disconnect that by using the spudger to pull up on the clip.
  10. LG G Pad 10.1 Speaker Replacement: adım 10, 1 resimden 1.
    • Now that all of the wires and screws are disconnected, use the spudger or a prying tool on the bottom corner of the motherboard to release it from one of the clips holding it in place.
  11. LG G Pad 10.1 Speaker Replacement: adım 11, 1 resimden 1.
    • Once the corner is removed, repeat the same action at the far end of the motherboard to release the second clip.
  12. LG G Pad 10.1 Speaker Replacement, Speaker: adım 12, 1 resimden 1.
    • Remove the single 4 mm Phillips #000 screw securing the speaker.
  13. LG G Pad 10.1 Speaker Replacement: adım 13, 1 resimden 1.
    • Remove the protective tape that is covering the speaker connections to the device by pulling upwards with either tweezers or your hands.
  14. LG G Pad 10.1 Speaker Replacement: adım 14, 2 resimden 1. LG G Pad 10.1 Speaker Replacement: adım 14, 2 resimden 2.
    • While holding the orange ribbon cable in place with your finger, grab the wires and pull upwards to disconnect the speaker from the device.
  15. LG G Pad 10.1 Speaker Replacement: adım 15, 1 resimden 1.
    • Using either the prying tool or your hands, pull the speaker to remove it from the tablet.
  16. LG G Pad 10.1 Speaker Replacement: adım 16, 1 resimden 1.
    • Remove the two 4 mm Phillips #000 screws.
  17. LG G Pad 10.1 Speaker Replacement: adım 17, 1 resimden 1.
    • Once the screws are removed, pull the speaker up with either the tweezers or plastic opening tool.
  18. LG G Pad 10.1 Speaker Replacement: adım 18, 1 resimden 1.
    • If you have been following steps to remove both speakers, skip this step.
  19. LG G Pad 10.1 Speaker Replacement: adım 19, 2 resimden 1. LG G Pad 10.1 Speaker Replacement: adım 19, 2 resimden 2.
    • Trace the red and black wire down the side of the device while sliding it out from under the small black clips as you work your way towards the end of the cable.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Alex Roszkowski
2.325 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 15-1, Blackwell Fall 2015 USF Tampa, Team 15-1, Blackwell Fall 2015 üyesi
USFT-BLACKWELL-F15S15G1
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 1
Her zaman: 982
