Giriş
Before starting, be sure that your tablet is turned off and that your work surface is clean. This is to avoid any unnecessary scratches since your screen will be facedown for the bulk of the replacement process.
Neye ihtiyacın var
Remove the front panel by separating the glass screen from the plastic encasing using a non-marrying pry tool.
Avoid using excessive force around the USB charging port to avoid damaging it .
Neredeyse bitti!
Sonuç
