Giriş
In cases where the front facing camera is not responding or isn’t powering on, this guide will help you replace the camera to fix these issues.
Neye ihtiyacın var
Power off your device before beginning the battery replacement (hold the button with the red marker until the device prompts you to power it off, then tap "Power Off").
Disconnect the battery connector by prying it upwards (red marker).
Remove the ribbon cables by prying them upwards with a plastic pry tool ).
Bir başkası bu kılavuzu tamamladı.
