Ana içeriğe geç
LG G Pad 7.0 LTE Speaker Replacement
Neye ihtiyacın var
  1. LG G Pad 7.0 LTE Speaker Replacement, Removing the Back Cover: adım 1, 1 resimden 1.
    • Power off your device before beginning the battery replacement (hold the button with the red marker until the device prompts you to power it off, then tap "Power Off").
    • Be wary of the front screen and SIM Card while tearing down the device.
  2. LG G Pad 7.0 LTE Speaker Replacement: adım 2, 1 resimden 1.
    Bu adımda kullanılan alet:
    Anti-Static Wrist Strap
    $7.95
    Satın Al
    • Put on an Anti-Static Wrist Strap to prevent damage to sensitive electrical components (optional).
    • To separate the frame from the cover, pry between the screen and the cover using a plastic prying tool.
    • Begin at the top left of the device to avoid damaging the motherboard and work your way around the perimeter of the screen.
    • When you pry your device open, be wary of the volume rockers, motherboard, and camera. These components are delicate and can be sensitive to static electricity.
  3. LG G Pad 7.0 LTE Speaker Replacement, Speaker: adım 3, 1 resimden 1.
    • Remove (1) Silver 3mm PH0 screw from the speaker (red marker).
  4. LG G Pad 7.0 LTE Speaker Replacement: adım 4, 1 resimden 1.
    • Remove speaker from device.
Sonuç
Fadi Bitar
880 İtibar
6 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 14-6, Eyestone Fall 2016 USF Tampa, Team 14-6, Eyestone Fall 2016 üyesi
USFT-EYESTONE-F16S14G6
4 Üyeler
12 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 415
