Ana içeriğe geç
LG G Pad 8.3 4G Back Camera Replacement
Neye ihtiyacın var
  1. LG G Pad 8.3 4G Back Camera Replacement, Back Panel: adım 1, 1 resimden 1.
    • With the screen faced up, insert the metal spudger into the crevice so that it is sticking out between the side panel and the screen.
    • Be gentle when popping the panel off.
  2. LG G Pad 8.3 4G Back Camera Replacement: adım 2, 3 resimden 1. LG G Pad 8.3 4G Back Camera Replacement: adım 2, 3 resimden 2. LG G Pad 8.3 4G Back Camera Replacement: adım 2, 3 resimden 3.
    • Take the spudger and slide it around the perimeter of the device.
    • Pull gently on the edges to get the panel to pop up.
    • If the panel does not budge, be aware that there is adhesive on the back of the battery holding the back shut. Make sure to just move around the perimeter of the back panel until the panel is able to lift forward.
  3. LG G Pad 8.3 4G Back Camera Replacement, Back Camera: adım 3, 2 resimden 1. LG G Pad 8.3 4G Back Camera Replacement, Back Camera: adım 3, 2 resimden 2.
    • Place metal spudger under edge of the IT1430 and lift vertically.
    • The IT1430 looks like a small cube with a yellow bar hanging off the side.
  4. LG G Pad 8.3 4G Back Camera Replacement: adım 4, 2 resimden 1. LG G Pad 8.3 4G Back Camera Replacement: adım 4, 2 resimden 2.
    Bu adımda kullanılan alet:
    Satın Al
    • Insert spudger to the right edge of the gold band and gently pry it up to disconnect the chip.
    • Repeat step with top and bottom sides.
    • Remove with tweezers.
    • Be careful when inserting the spudger behind the gold band because it is possible to tear it.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 3
Her zaman: 214
