Giriş
If your front facing camera is not working properly, it may be time to replace it. This guide will show you how to replace the front facing camera.
Neye ihtiyacın var
With the tablet face down, pull the SD card slot cover out.
Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
Use a plastic opening tool to lift the front facing camera out of the device.
Bir başkası bu kılavuzu tamamladı.
