Giriş
If your rear facing camera is not working, it may be time to replace it. This guide will show you how to replace the rear facing camera.
Aletler
Parçalar
Hiçbir parça belirtilmedi.
With the tablet face down, pull the SD card slot cover out.
Using a Phillips #000 screwdriver, remove the 3mm screw located in the SD card slot.
Remove the four 3 mm Phillips #000 screws that are attached to the speaker.
Use a plastic opening tool to remove the camera, which is attached with adhesive to the front of the tablet.
Neredeyse bitti!
Sonuç
