Ana içeriğe geç
LG G Pad F 7.0 Battery Replacement
Neye ihtiyacın var
  1. LG G Pad F 7.0 Battery Replacement, Battery: adım 1, 2 resimden 1. LG G Pad F 7.0 Battery Replacement, Battery: adım 1, 2 resimden 2.
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out.
    • Remove SIM card and set aside.
  2. LG G Pad F 7.0 Battery Replacement: adım 2, 2 resimden 1. LG G Pad F 7.0 Battery Replacement: adım 2, 2 resimden 2.
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Battery Replacement: adım 3, 1 resimden 1.
    • Locate the large orange ribbon cable, pry off the side shown in the image.
  4. LG G Pad F 7.0 Battery Replacement: adım 4, 2 resimden 1. LG G Pad F 7.0 Battery Replacement: adım 4, 2 resimden 2.
    • Use the plastic opening tool to pry the multicolor wire cables off, applying force up away from the tablet.
    • Use the plastic opening tool to pry up the battery. There is adhesive underneath the battery, so use a small amount of force. Work your way around the edge of the battery to pry it off.
Sonuç
Matt Kloos
249 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-5, Banghart Winter 2017 Cal Poly, Team 8-5, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S8G5
3 Üyeler
10 adet Kılavuz yazıldı
1Rehber Yorum
Pictures are all in focus and easy to follow
Jonah Basl - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 10
Her zaman: 767
