Ana içeriğe geç
LG G Pad F 7.0 Charging Port Replacement
Neye ihtiyacın var
  1. LG G Pad F 7.0 Charging Port  Replacement, Charging Port: adım 1, 2 resimden 1. LG G Pad F 7.0 Charging Port  Replacement, Charging Port: adım 1, 2 resimden 2.
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out.
    • Remove SIM card and set aside.
  2. LG G Pad F 7.0 Charging Port  Replacement: adım 2, 2 resimden 1. LG G Pad F 7.0 Charging Port  Replacement: adım 2, 2 resimden 2.
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Charging Port  Replacement: adım 3, 1 resimden 1.
    • Locate the top of the large orange ribbon cable.
    • Pry it off with the plastic opening tool as shown in the image.
  4. LG G Pad F 7.0 Charging Port  Replacement: adım 4, 2 resimden 1. LG G Pad F 7.0 Charging Port  Replacement: adım 4, 2 resimden 2.
    • Remove the gyroscope (the blue rectangular cube) located near the bottom of the device with the plastic opening tool as shown in the image.
    • Remove the speaker located in the bottom right corner of the device with the plastic opening tool as shown in the image.
  5. LG G Pad F 7.0 Charging Port  Replacement: adım 5, 2 resimden 1. LG G Pad F 7.0 Charging Port  Replacement: adım 5, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Remove the two screws located on the charging port as seen in the image using the Phillips screwdriver.
    • Using the tweezers, remove the orange ribbon cable along with the charging port.
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Erik
293 İtibar
1 Kılavuz yazıldı
Ekip
Cal Poly, Team 8-5, Banghart Winter 2017 Cal Poly, Team 8-5, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S8G5
3 Üyeler
10 adet Kılavuz yazıldı
4 Yorum
Good work, Pictures are clear and easy to follow
Jonah Basl - Yanıt
Just a minor item. On step 4 it tells you to remove the gyroscope, then remove the speaker. On on the unit I worked in you had to remove the speaker so you could get remove the gyroscope. I was working on the 8.0 instead of the 7.0 model, so perhaps that accounted for the difference.
Alan Siebens - Yanıt
Where do you buy the new charging port you need to put in? It's like gold lined teeth top and bottom.
Stands For Jesus - Yanıt
Also on his LG can we turn it into a prepaid monthly service if we get a at&t sim card kit or something similar?
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 4
Her zaman: 4,145
