Ana içeriğe geç
LG G Pad F 7.0 Motherboard Replacement
Neye ihtiyacın var
  1. LG G Pad F 7.0 Motherboard Replacement, Rear Camera: adım 1, 2 resimden 1. LG G Pad F 7.0 Motherboard Replacement, Rear Camera: adım 1, 2 resimden 2.
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out
    • Remove SIM card and set aside
  2. LG G Pad F 7.0 Motherboard Replacement: adım 2, 1 resimden 1.
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Motherboard Replacement: adım 3, 2 resimden 1. LG G Pad F 7.0 Motherboard Replacement: adım 3, 2 resimden 2.
    Bu adımda kullanılan alet:
    • Use the plastic opening tool to pry up the ribbon cable connecting to the camera unit.
    • One the ribbon cable has been detached, use the tweezers to pull up the camera. It is attached with adhesive so pull up gently to remove it.
    • Once the old camera unit is removed, replace with new unit and reassemble in reverse order of guide.
  4. LG G Pad F 7.0 Motherboard Replacement, Motherboard: adım 4, 1 resimden 1.
    • Locate the large orange ribbon cable, pry off the side shown in the image.
  5. LG G Pad F 7.0 Motherboard Replacement: adım 5, 2 resimden 1. LG G Pad F 7.0 Motherboard Replacement: adım 5, 2 resimden 2.
    • Use the plastic opening tool to pry the multicolor wire cables off, applying force up away from the tablet.
    • Use the plastic opening tool to pry up the battery. There is adhesive underneath the battery, so use a small amount of force. Work your way around the edge of the battery to pry it off.
  6. LG G Pad F 7.0 Motherboard Replacement: adım 6, 2 resimden 1. LG G Pad F 7.0 Motherboard Replacement: adım 6, 2 resimden 2.
    • Locate the front facing camera ribbon cable attachment on the motherboard
    • Leave the ribbon cable disconnected.
  7. LG G Pad F 7.0 Motherboard Replacement: adım 7, 2 resimden 1. LG G Pad F 7.0 Motherboard Replacement: adım 7, 2 resimden 2.
    • Locate the six Phillips head screws on the LG G Pad F 7.0 Motherboard
    • Use Phillips #0 Screwdriver to unscrew the six screws.
  8. LG G Pad F 7.0 Motherboard Replacement: adım 8, 2 resimden 1. LG G Pad F 7.0 Motherboard Replacement: adım 8, 2 resimden 2.
    • Remove the motherboard by prying it out with the plastic opening tool (as shown in image).
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jose Hurtado
329 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-5, Banghart Winter 2017 Cal Poly, Team 8-5, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S8G5
3 Üyeler
10 adet Kılavuz yazıldı
1 Guide Comment
Some spelling errors but overall simple to follow
Jonah Basl - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 3
Her zaman: 558
