Ana içeriğe geç
LG G Pad F 7.0 Speaker Replacement
Neye ihtiyacın var
  1. LG G Pad F 7.0 Speaker Replacement, Speaker: adım 1, 2 resimden 1. LG G Pad F 7.0 Speaker Replacement, Speaker: adım 1, 2 resimden 2.
    • Open up the SIM port, on the top right corner (screen face down).
    • Press the SIM card (white plastic) to pop it out.
    • Remove SIM card and set aside.
  2. LG G Pad F 7.0 Speaker Replacement: adım 2, 2 resimden 1. LG G Pad F 7.0 Speaker Replacement: adım 2, 2 resimden 2.
    • Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
    • Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
    • Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
  3. LG G Pad F 7.0 Speaker Replacement: adım 3, 3 resimden 1. LG G Pad F 7.0 Speaker Replacement: adım 3, 3 resimden 2. LG G Pad F 7.0 Speaker Replacement: adım 3, 3 resimden 3.
    • Locate the LG G Pad F 7.0 speaker
    • Insert the plastic opening tool on an edge of the speaker and lift so that it comes off easily
    • Remove old speaker and replace with a new one
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Jose Hurtado
329 İtibar
2 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 8-5, Banghart Winter 2017 Cal Poly, Team 8-5, Banghart Winter 2017 üyesi
CPSU-BANGHART-W17S8G5
3 Üyeler
10 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 0
Her zaman: 210
