Giriş
This covers how to replace the speaker on a LG G Pad F 7.0
Neye ihtiyacın var
Open up the SIM port, on the top right corner (screen face down).
Press the SIM card (white plastic) to pop it out.
Remove SIM card and set aside.
Use the plastic opening tool to pry the plastic backing off of the internal block. Start at the location with the SIM port to avoid damage to internal components.
Do this by finding the seam between the edge of the screen and the plastic backing, and prying between the two.
Work your way all the way around the edge of the screen, and remove the plastic backing when it is loose.
2 farklı kişi bu kılavuzu tamamladı.
