Ana içeriğe geç
LG G Vista Motherboard Replacement
Neye ihtiyacın var
  1. LG G Vista Motherboard Replacement, Battery: adım 1, 1 resimden 1.
    • Make sure the device is powered off.
  2. LG G Vista Motherboard Replacement: adım 2, 1 resimden 1.
    • Remove the back cover by gently prying open the case of the device from the charging port.
  3. LG G Vista Motherboard Replacement: adım 3, 1 resimden 1.
    • Lift the battery out of its place by prying up from the small notch at the base of the battery.
  4. LG G Vista Motherboard Replacement, Motherboard: adım 4, 1 resimden 1.
    • Remove the eight 3.0 mm screws using the Phillips #000 screwdriver.
  5. LG G Vista Motherboard Replacement: adım 5, 1 resimden 1.
    • Remove the hard shell covering the motherboard.
  6. LG G Vista Motherboard Replacement: adım 6, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use a pair of tweezers to lift up the white antenna wire. On the other side of the logic board, do the same for the black antenna wire.
  7. LG G Vista Motherboard Replacement: adım 7, 2 resimden 1. LG G Vista Motherboard Replacement: adım 7, 2 resimden 2.
    • Use the tweezers to remove the four connectors as well as the back camera.
    • Be careful not to directly touch the camera lenses.
  8. LG G Vista Motherboard Replacement: adım 8, 1 resimden 1.
    • Lift up and remove the motherboard from the device.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 1
Son 30 gün: 8
Her zaman: 475
