Giriş
If moisture has entered your LG G Watch, you will need to replace the gasket, and possibly the battery and the motherboard.
Neye ihtiyacın var
Bu adımda kullanılan alet:Tweezers$4.99
First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
Grasp the exposed shoulder with the tweezers to perform the next step.
Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
Use a pair of tweezers to remove the gasket that lies embedded in a groove that runs around the perimeter of the front half.
Bir başkası bu kılavuzu tamamladı.
