Ana içeriğe geç
LG G Watch R Battery Housing
Neye ihtiyacın var
  1. LG G Watch R Battery Housing, Back Case: adım 1, 2 resimden 1. LG G Watch R Battery Housing, Back Case: adım 1, 2 resimden 2.
    • Power off your watch before disassembling it.
    • Place the watch upside down on a hard surface so that its back case is facing upright.
    • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
  2. LG G Watch R Battery Housing: adım 2, 1 resimden 1.
    • Use a plastic opening tool to pry open the back case from both sides of the watch.
  3. LG G Watch R Battery Housing: adım 3, 1 resimden 1.
    • Remove the back case.
  4. LG G Watch R Battery Housing, Motherboard: adım 4, 2 resimden 1. LG G Watch R Battery Housing, Motherboard: adım 4, 2 resimden 2.
    • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
  5. LG G Watch R Battery Housing: adım 5, 2 resimden 1. LG G Watch R Battery Housing: adım 5, 2 resimden 2.
    • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
  6. LG G Watch R Battery Housing: adım 6, 1 resimden 1.
    • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
  7. LG G Watch R Battery Housing, Battery Replacement: adım 7, 1 resimden 1.
    • Use a plastic opening tool to pry the battery out of the device.
    • You may need to use a stronger prying force due to the adhesive that secures the battery to the case.
  8. LG G Watch R Battery Housing, Battery Housing Replacement: adım 8, 2 resimden 1. LG G Watch R Battery Housing, Battery Housing Replacement: adım 8, 2 resimden 2.
    • Pry the battery housing from the top right corner using a spudger.
    • Once loosened, remove the battery housing.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Westley Courchene
3.389 İtibar
14 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Remmell Fall 2015 USF Tampa, Team 1-1, Remmell Fall 2015 üyesi
USFT-REMMELL-F15S1G1
5 Üyeler
Bir Yorum
Hi there, do you know where can i buy the battery housing? Thank you..
Eugene Kang - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 14
Her zaman: 1,570
