Ana içeriğe geç
LG G Watch R Battery Replacement Replacement
Neye ihtiyacın var
    1. LG G Watch R Battery Replacement Replacement, Back Case: adım 1, 2 resimden 1. LG G Watch R Battery Replacement Replacement, Back Case: adım 1, 2 resimden 2.
      • Power off your watch before disassembling it.
      • Place the watch upside down on a hard surface so that its back case is facing upright.
      • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
      FixBot'a Sor
      Yorum Ekle
    2. LG G Watch R Battery Replacement Replacement: adım 2, 1 resimden 1.
      • Use a plastic opening tool to pry open the back case from both sides of the watch.
      FixBot'a Sor
      Yorum Ekle
    3. LG G Watch R Battery Replacement Replacement: adım 3, 1 resimden 1.
      • Remove the back case.
      FixBot'a Sor
      Yorum Ekle
    1. LG G Watch R Battery Replacement Replacement, Motherboard: adım 4, 2 resimden 1. LG G Watch R Battery Replacement Replacement, Motherboard: adım 4, 2 resimden 2.
      • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. LG G Watch R Battery Replacement Replacement: adım 5, 2 resimden 1. LG G Watch R Battery Replacement Replacement: adım 5, 2 resimden 2.
      • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. LG G Watch R Battery Replacement Replacement: adım 6, 1 resimden 1.
      • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
      FixBot'a Sor
      Yorum Ekle
    1. LG G Watch R Battery Replacement Replacement, Battery Replacement: adım 7, 1 resimden 1.
      • Use a plastic opening tool to pry the battery out of the device.
      • You may need to use a stronger prying force due to the adhesive that secures the battery to the case.
      FixBot'a Sor
      Yorum Ekle
Sonuç
71 farklı kişi bu kılavuzu tamamladı.
Westley Courchene
3.410 İtibar
14 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Remmell Fall 2015 USF Tampa, Team 1-1, Remmell Fall 2015 üyesi
USFT-REMMELL-F15S1G1
5 Üyeler
24 adet Kılavuz yazıldı
13Kılavuz Yorumları
The question is where i can find such battery ?
obada abu alhiga - Yanıt Paylaş
It did help, small correction - Use a T4 instead of T5 screw driver
Suyog Patki - Yanıt Paylaş
On my G Watch R the T5 screw driver perfektly fits.
igor-sweet - Yanıt Paylaş
I second the fonejoy link, got it delivered from them very quickly. And I also second what Suyog said regarding the Torx screwdriver, on my own watch I needed a T4, the T5 didn't work, but I had a set so I was okay.
Mike - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 14
Son 30 gün: 82
Her zaman: 31,713
