Ana içeriğe geç
LG G Watch R Power Button
Neye ihtiyacın var
    1. LG G Watch R Power Button, Back Case: adım 1, 2 resimden 1. LG G Watch R Power Button, Back Case: adım 1, 2 resimden 2.
      • Power off your watch before disassembling it.
      • Place the watch upside down on a hard surface so that its back case is facing upright.
      • Use a T4 Torx Star screwdriver to remove the four 4.0 mm Torx screws from the corners of the back case.
      FixBot'a Sor
      Yorum Ekle
    2. LG G Watch R Power Button: adım 2, 1 resimden 1.
      • Use a plastic opening tool to pry open the back case from both sides of the watch.
      FixBot'a Sor
      Yorum Ekle
    3. LG G Watch R Power Button: adım 3, 1 resimden 1.
      • Remove the back case.
      FixBot'a Sor
      Yorum Ekle
    1. LG G Watch R Power Button, Motherboard: adım 4, 2 resimden 1. LG G Watch R Power Button, Motherboard: adım 4, 2 resimden 2.
      • With a plastic opening tool, disconnect the four connectors on the top of the motherboard.
      FixBot'a Sor
      Yorum Ekle
    2. LG G Watch R Power Button: adım 5, 2 resimden 1. LG G Watch R Power Button: adım 5, 2 resimden 2.
      • Remove three 3.0 mm Phillips screws on the edges of the motherboard with a Phillips #000 screwdriver.
      FixBot'a Sor
      Yorum Ekle
    3. LG G Watch R Power Button: adım 6, 1 resimden 1.
      • Grasp the edges of the motherboard and slide it slightly towards the right to remove it from its case.
      FixBot'a Sor
      Yorum Ekle
    1. LG G Watch R Power Button, Battery Replacement: adım 7, 1 resimden 1.
      • Use a plastic opening tool to pry the battery out of the device.
      • You may need to use a stronger prying force due to the adhesive that secures the battery to the case.
      FixBot'a Sor
      Yorum Ekle
    1. LG G Watch R Power Button, Battery Housing Replacement: adım 8, 2 resimden 1. LG G Watch R Power Button, Battery Housing Replacement: adım 8, 2 resimden 2.
      • Pry the battery housing from the top right corner using a spudger.
      • Once loosened, remove the battery housing.
      FixBot'a Sor
      Yorum Ekle
    1. LG G Watch R Power Button, Power Button: adım 9, 3 resimden 1. LG G Watch R Power Button, Power Button: adım 9, 3 resimden 2. LG G Watch R Power Button, Power Button: adım 9, 3 resimden 3.
      Bu adımda kullanılan alet:
      • On the power button, locate a small grey washer on the interior side of the watch.
      • Use a pair of tweezers or another pointed object to push the washer out of its socket, and remove the power button.
      FixBot'a Sor
      Yorum Ekle
Sonuç
7 farklı kişi bu kılavuzu tamamladı.
Westley Courchene
3.410 İtibar
14 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 1-1, Remmell Fall 2015 USF Tampa, Team 1-1, Remmell Fall 2015 üyesi
USFT-REMMELL-F15S1G1
5 Üyeler
38 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 18
Son 30 gün: 56
Her zaman: 3,197
