Ana içeriğe geç
LG G Watch Rear Case Replacement
Neye ihtiyacın var
  1. LG G Watch Rear Case Replacement, Wristband: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
  2. LG G Watch Rear Case Replacement: adım 2, 2 resimden 1. LG G Watch Rear Case Replacement: adım 2, 2 resimden 2.
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
  3. LG G Watch Rear Case Replacement, Rear Case: adım 3, 1 resimden 1.
    • Use the T5 Torx screwdriver to unscrew the four silver 2mm x 3mm T5 screws that hold the back cover in place.
  4. LG G Watch Rear Case Replacement: adım 4, 2 resimden 1. LG G Watch Rear Case Replacement: adım 4, 2 resimden 2.
    • Slide the opening pick between the rear case and the rest of the device to separate the two halves.
    • Gently pull the two halves apart.
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Geoff Wacker
91.167 İtibar
89 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 7
Son 30 gün: 17
Her zaman: 965
