Ana içeriğe geç
LG G Watch Spring Bar Pin Replacement
Neye ihtiyacın var
  1. LG G Watch Spring Bar Pin Replacement, Wristband: adım 1, 1 resimden 1.
    Bu adımda kullanılan alet:
    • Spring bars attach the two halves of the wristband to the watch body. The spring bar has a shoulder on either end.
    • Be prepared to apply some pressure with your fingers to perform the following action.
    • First, slide the wristband down on the spring bar to expose the shoulder of the spring bar.
    • Grasp the exposed shoulder with the tweezers to perform the next step.
    FixBot'a Sor
    Yorum Ekle
  2. LG G Watch Spring Bar Pin Replacement: adım 2, 2 resimden 1. LG G Watch Spring Bar Pin Replacement: adım 2, 2 resimden 2.
    • This is a challenging step. Do it carefully to prevent the spring bar from flying out of the wristband.
    • Use the tweezer to depress the spring bar so that it collapses by a few millimeters and pops out of the hole that was holding it in place.
    • Now carefully pull the other end of the spring bar to detach the wristband from the watch face.
    • Repeat steps 1 and 2 for the other wristband.
    FixBot'a Sor
    Yorum Ekle
  3. LG G Watch Spring Bar Pin Replacement, Spring Bar Pin: adım 3, 1 resimden 1.
    • Slide the spring bar pin out of the wristband.
    • Repeat this step for the other wristband.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Bir başkası bu kılavuzu tamamladı.
Geoff Wacker
92.866 İtibar
89 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 40
Her zaman: 1,343
