Ana içeriğe geç
LG G2 mini LTE Rear Facing Camera Replacement
Neye ihtiyacın var
    1. LG G2 mini LTE Rear Facing Camera Replacement, Remove the Battery Cover: adım 1, 1 resimden 1.
      • Remove the back cover by placing your fingernail in the crease between the cover and the charging port.
      • Pry upward and the cover should pop off easily.
      FixBot'a Sor
      Yorum Ekle
    2. LG G2 mini LTE Rear Facing Camera Replacement, Remove the Battery: adım 2, 1 resimden 1.
      • Remove the battery from the battery bay by prying with your finger at the groove on the lower end of the battery bay.
      FixBot'a Sor
      Yorum Ekle
    3. LG G2 mini LTE Rear Facing Camera Replacement, Unscrew the Motherboard Cover: adım 3, 2 resimden 1. LG G2 mini LTE Rear Facing Camera Replacement, Unscrew the Motherboard Cover: adım 3, 2 resimden 2.
      • Locate 10 screws and remove each one using a screw driver.
      FixBot'a Sor
      Yorum Ekle
    4. LG G2 mini LTE Rear Facing Camera Replacement, Remove the Motherboard Cover: adım 4, 1 resimden 1.
      • Use a plastic spudger tool to pry away the cover by placing it between the cover and the screen bezel.
      • Pry all the way around the phone about every centimeter until the cover is completely separated from the phone.
      FixBot'a Sor
      Yorum Ekle
    5. LG G2 mini LTE Rear Facing Camera Replacement, Remove the Camera: adım 5, 3 resimden 1. LG G2 mini LTE Rear Facing Camera Replacement, Remove the Camera: adım 5, 3 resimden 2. LG G2 mini LTE Rear Facing Camera Replacement, Remove the Camera: adım 5, 3 resimden 3.
      • Locate the rear facing camera.
      • Pry the ribbon cable off of it's connector using the plastic spudger tool.
      • Use your finger to remove the camera.
      FixBot'a Sor
      Yorum Ekle
Sonuç
2 farklı kişi bu kılavuzu tamamladı.
Ekip
UMass Dartmouth, Team 1-9, Shastany Fall 2014 UMass Dartmouth, Team 1-9, Shastany Fall 2014 üyesi
UMASSD-SHASTANY-F14S1G9
3 Üyeler
60 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 4
Son 7 gün: 10
Son 30 gün: 44
Her zaman: 2,032
