Ana içeriğe geç
LG G3 Battery Replacement
Neye ihtiyacın var
  1. LG G3 Battery Replacement, Back Cover: adım 1, 2 resimden 1. LG G3 Battery Replacement, Back Cover: adım 1, 2 resimden 2.
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
  2. LG G3 Battery Replacement: adım 2, 2 resimden 1. LG G3 Battery Replacement: adım 2, 2 resimden 2.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
  3. LG G3 Battery Replacement, Battery: adım 3, 2 resimden 1. LG G3 Battery Replacement, Battery: adım 3, 2 resimden 2.
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
  4. LG G3 Battery Replacement: adım 4, 2 resimden 1. LG G3 Battery Replacement: adım 4, 2 resimden 2.
    • Lift the battery out of its recess and remove it.
Sonuç
For optimal performance, calibrate your newly installed battery: Charge it to 100%, and keep charging it for at least two more hours. Then, use it until it shuts off due to low battery. Finally, charge it uninterrupted to 100%.
21 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
202.809 İtibar
682 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.732 adet Kılavuz yazıldı
Bir Yorum
Thank you very much!
ItayDigital - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 8
Son 30 gün: 18
Her zaman: 17,567
