Giriş
In this guide, you will learn how to replace the power and volume flex cables in the LG G3.
Parçalar
Hiçbir parça belirtilmedi.
Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
Pry the back cover up to separate its plastic clips.
Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
Remove the last screw attaching the rear camera lens to the frame.
Now use a plastic spudger to carefully remove the camera lens.
9 farklı kişi bu kılavuzu tamamladı.
