Ana içeriğe geç
Giriş
The rear speaker is attached to the bottom panel of the LG G3, so to resolve any problems with the rear speaker, a full replacement of the bottom panel is necessary.
Videoya Genel Bakış
  1. Take your phone and place it screen down.
    • Take your phone and place it screen down.
  2. Start by lifting the back panel using the gap located on the bottom-left side of the phone. Insert the plastic opening tool into the gap and move it along the edge of the phone until the rear case pops off. Insert the plastic opening tool into the gap and move it along the edge of the phone until the rear case pops off.
    • Start by lifting the back panel using the gap located on the bottom-left side of the phone.
    • Insert the plastic opening tool into the gap and move it along the edge of the phone until the rear case pops off.
  3. Remove the battery from the phone. Remove the battery from the phone.
    • Remove the battery from the phone.
  4. Apple Watch Kitleri
    Screen and battery repairs just got easier.
    Hemen Alışveriş Yapın
    Apple Watch Kitleri
  5. Remove the 13 screws found on the back of the phone. The screw circled in red is shorter than the other 12 screws. For an easier time when reassembling the phone, store it separately from the other screws.
    • Remove the 13 screws found on the back of the phone.
    • The screw circled in red is shorter than the other 12 screws. For an easier time when reassembling the phone, store it separately from the other screws.
  6. Locate the same gap used in the earlier step Lift gently using your fingers
    • Locate the same gap used in the earlier step
    • Lift gently using your fingers
  7. Remove the bottom panel
    • Remove the bottom panel
  8. remove the speaker from the rear panel and insert the new speaker
    • remove the speaker from the rear panel and insert the new speaker
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Shannon
1.460 İtibar
2 adet Kılavuz yazıldı
Takım
UMass Dartmouth, Team 1-3, Duarte Fall 2014 UMass Dartmouth, Team 1-3, Duarte Fall 2014 üyesi
UMASSD-DUARTE-F14S1G3
4 Üyeler
14 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 5
Son 30 Gün: 21
Her zaman: 13,488
