Ana içeriğe geç
LG G3 Screen Assembly Replacement
Neye ihtiyacın var
  1. LG G3 Screen Assembly Replacement, Back Cover: adım 1, 2 resimden 1. LG G3 Screen Assembly Replacement, Back Cover: adım 1, 2 resimden 2.
    • Power off your phone before beginning disassembly.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover.
    • Pry the back cover up to separate its plastic clips.
    FixBot'a Sor
    Yorum Ekle
  2. LG G3 Screen Assembly Replacement: adım 2, 2 resimden 1. LG G3 Screen Assembly Replacement: adım 2, 2 resimden 2.
    • Lift the back cover to release the rest of the plastic clips and remove it.
    • In case you can't lift the back cover completely, slide your fingernail or your prying tool around the midframe to release the remaining clips.
    • To reinstall the back cover, press it firmly into place until you hear a snap from the plastic clips to form a seamless connection with the rear side of the phone.
    FixBot'a Sor
    Yorum Ekle
  3. LG G3 Screen Assembly Replacement, Battery: adım 3, 2 resimden 1. LG G3 Screen Assembly Replacement, Battery: adım 3, 2 resimden 2.
    • Use a fingernail or a prying tool at the marked notch to lever the battery out of its recess.
    FixBot'a Sor
    Yorum Ekle
  4. LG G3 Screen Assembly Replacement: adım 4, 2 resimden 1. LG G3 Screen Assembly Replacement: adım 4, 2 resimden 2.
    • Lift the battery out of its recess and remove it.
    FixBot'a Sor
    Yorum Ekle
  5. LG G3 Screen Assembly Replacement, Loudspeaker: adım 5, 1 resimden 1.
    • Remove the four Phillips #00 screws (4 mm length).
    FixBot'a Sor
    Yorum Ekle
  6. LG G3 Screen Assembly Replacement: adım 6, 2 resimden 1. LG G3 Screen Assembly Replacement: adım 6, 2 resimden 2.
    • Insert a thumbnail, or a prying tool like a spudger, into the notch at the bottom left of the back cover you used earlier to remove the back cover.
    • Pry up the plastic panel, including the loudspeaker, until you can get a good grip.
    FixBot'a Sor
    Yorum Ekle
  7. LG G3 Screen Assembly Replacement: adım 7, 3 resimden 1. LG G3 Screen Assembly Replacement: adım 7, 3 resimden 2. LG G3 Screen Assembly Replacement: adım 7, 3 resimden 3.
    • Carefully remove the plastic panel including the loudspeaker by gently pulling it away from the phone assembly.
    FixBot'a Sor
    Yorum Ekle
  8. LG G3 Screen Assembly Replacement, Motherboard Cover Assembly: adım 8, 1 resimden 1.
    • Remove the eight Phillips #00 screws (4 mm length).
    FixBot'a Sor
    Yorum Ekle
  9. LG G3 Screen Assembly Replacement: adım 9, 3 resimden 1. LG G3 Screen Assembly Replacement: adım 9, 3 resimden 2. LG G3 Screen Assembly Replacement: adım 9, 3 resimden 3.
    • Insert an opening pick between the bottom right corner of the motherboard cover and the motherboard.
    • Pry up the motherboard cover to open the plastic clips which hold the cover in its place.
    • The clips can be a bit resistive. If you're having trouble prying up the motherboard cover, slightly rotate the opening pick sideways to make the process easier.
    • Work your way along the right edge.
    FixBot'a Sor
    Yorum Ekle
  10. LG G3 Screen Assembly Replacement: adım 10, 3 resimden 1. LG G3 Screen Assembly Replacement: adım 10, 3 resimden 2. LG G3 Screen Assembly Replacement: adım 10, 3 resimden 3.
    • Carefully lift the right edge of the motherboard cover.
    • The remaining plastic clips should open during this process or can be unhinged easily by hand.
    • Remove the motherboard assembly.
    FixBot'a Sor
    Yorum Ekle
  11. LG G3 Screen Assembly Replacement, Motherboard: adım 11, 2 resimden 1. LG G3 Screen Assembly Replacement, Motherboard: adım 11, 2 resimden 2.
    • Use a spudger to pry up and disconnect the display flex cable.
    FixBot'a Sor
    Yorum Ekle
  12. LG G3 Screen Assembly Replacement: adım 12, 2 resimden 1. LG G3 Screen Assembly Replacement: adım 12, 2 resimden 2.
    • Use a spudger to pry up and disconnect the digitizer flex cable.
    FixBot'a Sor
    Yorum Ekle
  13. LG G3 Screen Assembly Replacement: adım 13, 2 resimden 1. LG G3 Screen Assembly Replacement: adım 13, 2 resimden 2.
    • Use a spudger to pry up and disconnect the rear camera flex cable.
    FixBot'a Sor
    Yorum Ekle
  14. LG G3 Screen Assembly Replacement: adım 14, 2 resimden 1. LG G3 Screen Assembly Replacement: adım 14, 2 resimden 2.
    • Use a spudger to pry up and disconnect the front camera flex cable.
    FixBot'a Sor
    Yorum Ekle
  15. LG G3 Screen Assembly Replacement: adım 15, 2 resimden 1. LG G3 Screen Assembly Replacement: adım 15, 2 resimden 2.
    • During these next few steps, make sure to avoid damaging the flex cables you disconnected.
    • Slide an opening pick under the bottom right corner of the motherboard and slowly pry it out of its recess by rotating the opening pick sideways.
    FixBot'a Sor
    Yorum Ekle
  16. LG G3 Screen Assembly Replacement: adım 16, 2 resimden 1. LG G3 Screen Assembly Replacement: adım 16, 2 resimden 2.
    • Slide the opening pick under the right edge of the motherboard where the SIM card slot is located and pry it up by rotating the opening pick sideways.
    FixBot'a Sor
    Yorum Ekle
  17. LG G3 Screen Assembly Replacement: adım 17, 2 resimden 1. LG G3 Screen Assembly Replacement: adım 17, 2 resimden 2.
    • Grab the top section of the motherboard and carefully lift it out of the phone.
    FixBot'a Sor
    Yorum Ekle
  18. LG G3 Screen Assembly Replacement, Screen Assembly: adım 18, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  19. LG G3 Screen Assembly Replacement: adım 19, 2 resimden 1. LG G3 Screen Assembly Replacement: adım 19, 2 resimden 2.
    Bu adımda kullanılan alet:
    • During the removal of the earpiece speaker, remove it together with the foam gasket underneath.
    • Use a pair of tweezers to remove the earpiece speaker.
    FixBot'a Sor
    Yorum Ekle
  20. LG G3 Screen Assembly Replacement: adım 20, 2 resimden 1. LG G3 Screen Assembly Replacement: adım 20, 2 resimden 2.
    • Use a pair of tweezers to remove the front camera.
    FixBot'a Sor
    Yorum Ekle
  21. LG G3 Screen Assembly Replacement: adım 21, 2 resimden 1. LG G3 Screen Assembly Replacement: adım 21, 2 resimden 2.
    • If you're having trouble removing the rear camera or the vibration motor, reapply the heated iOpener to loosen the adhesive underneath.
    • Use a pair of tweezers to remove the rear camera.
    FixBot'a Sor
    Yorum Ekle
  22. LG G3 Screen Assembly Replacement: adım 22, 3 resimden 1. LG G3 Screen Assembly Replacement: adım 22, 3 resimden 2. LG G3 Screen Assembly Replacement: adım 22, 3 resimden 3.
    • Insert one of the tweezer arms under the vibration motor and pry it up.
    • Remove the vibration motor.
    FixBot'a Sor
    Yorum Ekle
  23. LG G3 Screen Assembly Replacement: adım 23, 1 resimden 1.
    FixBot'a Sor
    Yorum Ekle
  24. LG G3 Screen Assembly Replacement: adım 24, 3 resimden 1. LG G3 Screen Assembly Replacement: adım 24, 3 resimden 2. LG G3 Screen Assembly Replacement: adım 24, 3 resimden 3.
    • Use the pointed end of a spudger to pry up the headphone jack and remove it with a pair of tweezers.
    FixBot'a Sor
    Yorum Ekle
  25. LG G3 Screen Assembly Replacement: adım 25, 3 resimden 1. LG G3 Screen Assembly Replacement: adım 25, 3 resimden 2. LG G3 Screen Assembly Replacement: adım 25, 3 resimden 3.
    • Use a pair of tweezers to carefully pry up and remove the daughterboard at the bottom end of the screen assembly.
    FixBot'a Sor
    Yorum Ekle
  26. LG G3 Screen Assembly Replacement: adım 26, 1 resimden 1.
    • Compare your new replacement part to the original part—you may need to transfer remaining components or remove adhesive backings from the new part before installing.
    FixBot'a Sor
    Yorum Ekle
Sonuç
To reassemble your device, follow these instructions in reverse order. Apply new adhesive where it’s necessary.
If possible turn on your phone and test your replacement part before reassembling your phone.
Repair didn’t go as planned? Try some basic troubleshooting, or ask our Answers Community for help.
130 farklı kişi bu kılavuzu tamamladı.
Dominik Schnabelrauch
261.093 İtibar
682 adet Kılavuz yazıldı
43Kılavuz Yorumları
Ok so after I did all this my screen is black and so I ordered a second screen and also nothing the phone works great and makes noises also touch responds but nothing on lcd just black can you help me with this also if I take battery out and plug up charger it shows a battery warning on lcd so clearly it works
cabinlife27030 - Yanıt Paylaş
Has it sustained any water damage?
Josiah Leas - Yanıt Paylaş
Did you get it working i have the same issue? the picture displays with the original screen but not with the new one. i have tried 3 different screens and get the same on all of them. i even tried updating to the latest software but only get a black screen, no picture.
When i have had this on iphones i just so a reset by holding down the buttons and the screen starts to work.
Please someone help
Matt - Yanıt Paylaş
Same here! I also findout that lcd still works, if you get some flashlight on screen in a dark room, you will see that only backlight not working when battery plugged. I tried to baking it but it still didn't worked. It's obvious that backlight could properly operate as it works when you take off the battery. I'm looking for solutions, if I find any, will wrote it here.
tufekcisencer - Yanıt Paylaş
Did someone find a solution to this? I also replaced my screen and it keeps black solid when I turn it on, even with the touch working properly.
fsnaderfb - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 14
Son 30 gün: 73
Her zaman: 252,579
