Ana içeriğe geç
LG G3 Vigor Motherboard Replacement
Neye ihtiyacın var
  1. LG G3 Vigor Motherboard Replacement, Rear Case: adım 1, 1 resimden 1.
    • Locate the notch on the bottom right of the phone.
  2. LG G3 Vigor Motherboard Replacement: adım 2, 1 resimden 1.
    • Gently pull the cover on the back of the phone off to locate the battery.
  3. LG G3 Vigor Motherboard Replacement, Battery: adım 3, 1 resimden 1.
    • Remove the battery by lifting from the slot at the bottom of the battery.
  4. LG G3 Vigor Motherboard Replacement, Midframe: adım 4, 1 resimden 1.
    • Remove the twelve Phillips #00 screws securing the midframe to the rest of the phone.
  5. LG G3 Vigor Motherboard Replacement: adım 5, 3 resimden 1. LG G3 Vigor Motherboard Replacement: adım 5, 3 resimden 2. LG G3 Vigor Motherboard Replacement: adım 5, 3 resimden 3.
    • Work a plastic opening tool around the perimeter of the phone to separate the midframe from the rest of the phone.
  6. LG G3 Vigor Motherboard Replacement, Rear Facing Camera: adım 6, 1 resimden 1.
    • Use the spudger to gently unplug the ribbon cable connected to the motherboard. Then remove the rear facing camera.
  7. LG G3 Vigor Motherboard Replacement, Front Facing Camera: adım 7, 2 resimden 1. LG G3 Vigor Motherboard Replacement, Front Facing Camera: adım 7, 2 resimden 2.
    • Remove the front camera.
  8. LG G3 Vigor Motherboard Replacement, Motherboard: adım 8, 1 resimden 1.
    • Use the flat edge of a spudger to disconnect the motherboard ribbon connector.
  9. LG G3 Vigor Motherboard Replacement: adım 9, 2 resimden 1. LG G3 Vigor Motherboard Replacement: adım 9, 2 resimden 2.
    • Use the pointed end of a spudger to push back the two motherboard retaining flaps.
    • The motherboard should now be able to be lifted out of the device.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
Jared Stickl
407 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 12-5, Eyestone Spring 2016 USF Tampa, Team 12-5, Eyestone Spring 2016 üyesi
USFT-EYESTONE-S16S12G5
4 Üyeler
5 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 3
Her zaman: 2,004
