Ana içeriğe geç
LG G4 Back Cover Replacement
Neye ihtiyacın var
  1. LG G4 Back Cover Replacement, Back Cover: adım 1, 1 resimden 1.
    • Make sure the phone is powered off.
    • Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
  2. LG G4 Back Cover Replacement: adım 2, 2 resimden 1. LG G4 Back Cover Replacement: adım 2, 2 resimden 2.
    • Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
  3. LG G4 Back Cover Replacement: adım 3, 3 resimden 1. LG G4 Back Cover Replacement: adım 3, 3 resimden 2. LG G4 Back Cover Replacement: adım 3, 3 resimden 3.
    • Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
  4. LG G4 Back Cover Replacement: adım 4, 3 resimden 1. LG G4 Back Cover Replacement: adım 4, 3 resimden 2. LG G4 Back Cover Replacement: adım 4, 3 resimden 3.
    • Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
    • Detach the cover with your fingers
Sonuç
9 farklı kişi bu kılavuzu tamamladı.
carolinavind
2.699 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-5, Wollert Fall 2015 USF Tampa, Team 16-5, Wollert Fall 2015 üyesi
USFT-WOLLERT-F15S16G5
4 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 0
Son 30 gün: 16
Her zaman: 7,906
