Giriş
This guide shows you how to replace the headphone port.
Neye ihtiyacın var
Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
Gently wedge the plastic opening tool under the ribbons where each of the three cables are connected, and gently lift up to detach the cable.
7 farklı kişi bu kılavuzu tamamladı.
8 Yorum
My g4's headphone could only produce sound on one side. So i bought a new headphone jack from ebay and replaced it. The problem still persists. Does this mean it could be a motherboard issue?
Or a headphone issue. You did try a different pair of headphones?
i did the same as pholklorr with my g4 but bought oem and still doesn't work you can only hear it from one side
Great! My headphone port couldn't hold my headphones anymore because of wear & tear (they kept falling out) but this guide and a 6 dollar ebay-item fixed it! Thanks a lot.
