Ana içeriğe geç
LG G4 Speaker Replacement
Neye ihtiyacın var
  1. LG G4 Speaker Replacement, Back Cover: adım 1, 1 resimden 1.
    • Make sure the phone is powered off.
    • Remove the rear cover by placing the plastic opening tool in the groove on the bottom left side of the LG G4 and gently prying up.
  2. LG G4 Speaker Replacement: adım 2, 2 resimden 1. LG G4 Speaker Replacement: adım 2, 2 resimden 2.
    • Place the plastic opening tool at the bottom edge of the battery and lift up. Carefully remove battery with your hands.
  3. LG G4 Speaker Replacement: adım 3, 3 resimden 1. LG G4 Speaker Replacement: adım 3, 3 resimden 2. LG G4 Speaker Replacement: adım 3, 3 resimden 3.
    • Remove the eleven 3.9 mm Phillips #00 screws found at the back of the phone.
  4. LG G4 Speaker Replacement: adım 4, 3 resimden 1. LG G4 Speaker Replacement: adım 4, 3 resimden 2. LG G4 Speaker Replacement: adım 4, 3 resimden 3.
    • Once all the screws have been removed, place the plastic opening tool in the lower left corner and firmly lift the cover up.
    • Detach the cover with your fingers
  5. LG G4 Speaker Replacement, Speaker: adım 5, 2 resimden 1. LG G4 Speaker Replacement, Speaker: adım 5, 2 resimden 2.
    • Detach the bottom portion of the plastic panel you just removed by wedging the plastic opening tool under the top part of the clip, and sliding the bottom portion of the panel downward away from the top portion.
    • The bottom portion of the plastic panel contains the speaker to be replaced, all as one part.
Sonuç
8 farklı kişi bu kılavuzu tamamladı.
carolinavind
2.699 İtibar
3 adet Kılavuz yazıldı
Ekip
USF Tampa, Team 16-5, Wollert Fall 2015 USF Tampa, Team 16-5, Wollert Fall 2015 üyesi
USFT-WOLLERT-F15S16G5
4 Üyeler
15 adet Kılavuz yazıldı
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 1
Son 30 gün: 2
Her zaman: 6,961
