Neye ihtiyacın var
While holding the battery release button, pull the bottom end of the phone out of the body.
Locate the auxiliary port on the top right of the phone
Using a finger, carefully take the port out
8 farklı kişi bu kılavuzu tamamladı.
3 Yorum
I saw a video where someone used a guitar pick as the plastic opening tool, seems safer to me. And that person also had a great idea to shove a pencil in the battery bay to apply a separating force, so that as you work the seam with a guitar pick, the the two halves will naturally want to separate.
Hi, I have two LG G5 phone. Let's call them
A & B.
So , B overheats and the battery last less than an hour. So I took the battery from A and I put it in B and I put the B battery in the A. Results: B still overheats and not the A ??? I also left the connector blocks on the batteries when I did the switching. So what could be the cause of this?
weak signal problem
