Ana içeriğe geç
LG G5 Battery Replacement
Neye ihtiyacın var
  1. LG G5 Battery Replacement, Battery: adım 1, 3 resimden 1. LG G5 Battery Replacement, Battery: adım 1, 3 resimden 2. LG G5 Battery Replacement, Battery: adım 1, 3 resimden 3.
    • Power down the phone by holding the power button for several seconds.
    • While holding the battery release button, pull the bottom end of the phone out of the body.
  2. LG G5 Battery Replacement: adım 2, 2 resimden 1. LG G5 Battery Replacement: adım 2, 2 resimden 2.
    • Separate the battery from bottom half.
    • Insert the new battery in the same position and orientation as the old battery. Match up the arrows to be sure the orientation is correct.
    You should be able to pull it out by pulling down and away at the same time.
    This video has a better explanation of how its done.
    Germanetti Rosas - Yanıt
    Para temover a bateria, é só puxar???
    eliezerhenriquesilva - Yanıt
Sonuç
21 farklı kişi bu kılavuzu tamamladı.
Sam Goldheart
465.762 İtibar
538 adet Kılavuz yazıldı
Ekip
iFixit iFixit üyesi
Staff
135 Üyeler
16.817 adet Kılavuz yazıldı
4 Yorum
Success. Excellent guide, thank you.
Cheers,
Richard.
rmgs - Yanıt
Was machen wenn Akku Snap In ab ist?
Ra Ku - Yanıt
Hallo, was machen wenn Snap In vom Akku ab ist und Akku im Gehäuse fest sitzt?
Ra Ku - Yanıt
Absolutely great instructions. The battery I got for replacement comes uncharged (probably new shipping laws) so you might put in “Battery needs to be calibrated by fulling charging new battery to 100% then letting battery COMPLETELY run down to 0% before returning to normal use and charging.”
Michael Aarons - Yanıt
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 15
Son 30 gün: 72
Her zaman: 15,544
