Ana içeriğe geç
LG G5 Front Panel Assembly
Neye ihtiyacın var
  1. LG G5 Front Panel Assembly, Front Panel Assembly: adım 1, 2 resimden 1. LG G5 Front Panel Assembly, Front Panel Assembly: adım 1, 2 resimden 2.
    • While holding the battery release button, pull the bottom end of the phone out of the body.
    FixBot'a Sor
    Yorum Ekle
  2. LG G5 Front Panel Assembly: adım 2, 3 resimden 1. LG G5 Front Panel Assembly: adım 2, 3 resimden 2. LG G5 Front Panel Assembly: adım 2, 3 resimden 3.
    • Insert the sim card eject tool (0.8mm sim card eject head) into the small hole on the sim card tray.
    • Press inward with some force to eject the tray.
    • Pull the sim card tray out of the phone.
    FixBot'a Sor
    Yorum Ekle
  3. LG G5 Front Panel Assembly: adım 3, 2 resimden 1. LG G5 Front Panel Assembly: adım 3, 2 resimden 2.
    • Remove the two 5.5mm Phillips #00 screws from the base of the phone.
    FixBot'a Sor
    Yorum Ekle
  4. LG G5 Front Panel Assembly: adım 4, 1 resimden 1.
    • Insert the plastic opening tool into the seam between the glass screen and the metal body.
    • Pry the glass from the body only a slight amount.
    FixBot'a Sor
    Yorum Ekle
  5. LG G5 Front Panel Assembly: adım 5, 2 resimden 1. LG G5 Front Panel Assembly: adım 5, 2 resimden 2.
    • Insert the Spudger into the now open space between the body and screen.
    • Push inward to separate the screen even more.
    • Slowly slide the nylon spudger up the edge the phone till the screen pops out of the body.
    • When putting the screen back in, press the edges down from the top of the phone to the bottom. The screen should "pop" into place.
    FixBot'a Sor
    Yorum Ekle
  6. LG G5 Front Panel Assembly: adım 6, 2 resimden 1. LG G5 Front Panel Assembly: adım 6, 2 resimden 2.
    • Peel the screen away from the body. The two parts should be completely separated.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Now you can access all the inner components of the phone!
32 farklı kişi bu kılavuzu tamamladı.
Joshua Zalmanowitz
1.817 İtibar
4 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 18-2, Forte Fall 2016 Cal Poly, Team 18-2, Forte Fall 2016 üyesi
CPSU-FORTE-F16S18G2
4 Üyeler
21 adet Kılavuz yazıldı
4Kılavuz Yorumları
quickest 50 bucks i ever made, lol. Thanks for having the guide up.
Montez Hardnett - Yanıt Paylaş
Love this phone... So MODULAR! Thanks for the guide.. Had to double-check when I was pulling it apart.. almost seemed too easy.
Christopher Williams - Yanıt Paylaş
Wow, I didn't realise this phone was so modular, reminds me of the s4. I wish more phone were like it!!
Lucas - Yanıt Paylaş
Busted my screen running it up the side to pry it off. Next time I'd do the two bottom sides and lift up. The tapered edge on top seems to have been the problem for me.
Randy - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 9
Son 30 gün: 54
Her zaman: 10,666
