Ana içeriğe geç
LG G6 Motherboard Replacement
Arşivlenmiş Kılavuz
Bu kılavuz sadece arşivsel amaçlarla muhafaza edilmiştir. Onarımınızı gerçekleştirmek için kılavuzun güncel halini kullanın.
Neye ihtiyacın var
    1. LG G6 Motherboard Replacement, iOpener Heating: adım 1, 2 resimden 1. LG G6 Motherboard Replacement, iOpener Heating: adım 1, 2 resimden 2.
      • We recommend that you clean your microwave before proceeding, as any nasty gunk on the bottom may end up stuck to the iOpener.
      • Place the iOpener in the center of the microwave.
      • For carousel microwaves: Make sure the plate spins freely. If your iOpener gets stuck, it may overheat and burn.
      FixBot'a Sor
      Yorum Ekle
    2. LG G6 Motherboard Replacement: adım 2, 1 resimden 1.
      • Heat the iOpener for thirty seconds.
      • Depending on the wattage of your microwave, more or less time may be required. The iOpener is sufficiently heated when it's barely too hot to touch.
      • Throughout the repair procedure, as the iOpener cools, reheat it in the microwave for an additional thirty seconds at a time.
      • Be careful not to overheat the iOpener during the repair. Overheating may cause the iOpener to burst. Do not attempt to heat over 100˚C (212˚F).
      • Never touch the iOpener if it appears swollen.
      • If the iOpener is still too hot in the middle to touch, continue using it while waiting for it to cool down some more before reheating. A properly heated iOpener should stay warm for up to 10 minutes.
      FixBot'a Sor
      Yorum Ekle
    3. LG G6 Motherboard Replacement: adım 3, 1 resimden 1.
      • Remove the iOpener from the microwave, holding it by one of the two flat ends to avoid the hot center.
      • The iOpener will be very hot, so be careful when handling it. Use an oven mitt if necessary.
      FixBot'a Sor
      Yorum Ekle
    4. LG G6 Motherboard Replacement, Alternate iOpener heating method: adım 4, 2 resimden 1. LG G6 Motherboard Replacement, Alternate iOpener heating method: adım 4, 2 resimden 2.
      • If you don't have a microwave, follow this step to heat your iOpener in boiling water.
      • Fill a pot or pan with enough water to fully submerge an iOpener.
      • Heat the water to a boil. Turn off the heat.
      • Place an iOpener into the hot water for 2-3 minutes. Make sure the iOpener is fully submerged in the water.
      • Use tongs to extract the heated iOpener from the hot water.
      • Thoroughly dry the iOpener with a towel.
      • The iOpener will be very hot, so be careful to hold it only by the end tabs.
      • Your iOpener is ready for use! If you need to reheat the iOpener, heat the water to a boil, turn off the heat, and place the iOpener in the water for 2-3 minutes.
      FixBot'a Sor
      Yorum Ekle
    1. LG G6 Motherboard Replacement, Battery: adım 5, 1 resimden 1.
      • Apply the heated iOpener to the edge of the phone for about 2 minutes.
      FixBot'a Sor
      Yorum Ekle
    2. LG G6 Motherboard Replacement: adım 6, 3 resimden 1. LG G6 Motherboard Replacement: adım 6, 3 resimden 2. LG G6 Motherboard Replacement: adım 6, 3 resimden 3.
      Bu adımda kullanılan alet:
      Plastic Cards
      $2.99
      • When the back panel is heated, apply the suction cup close to a corner of the phone. Lift up and insert a halberd spudger or opening pick under the rear glass.
      • Slide the blade of the Halberd spudger along the edge of the phone to separate the adhesive.
      • Follow around the edge of the phone, and use an opening pick or other tool (such as a plastic card) to keep already opened portions from re-adhering.
      FixBot'a Sor
      Yorum Ekle
    3. LG G6 Motherboard Replacement: adım 7, 2 resimden 1. LG G6 Motherboard Replacement: adım 7, 2 resimden 2.
      • Using a Philips 000 bit, remove 11 screws from the highlighted locations.
      FixBot'a Sor
      Yorum Ekle
    4. LG G6 Motherboard Replacement: adım 8, 2 resimden 1. LG G6 Motherboard Replacement: adım 8, 2 resimden 2.
      • With the screws removed, remove the lower frame components, followed by the upper mid-frame. Both components can be removed with a little prying.
      FixBot'a Sor
      Yorum Ekle
    5. LG G6 Motherboard Replacement: adım 9, 1 resimden 1.
      • Begin battery removal by very gently prying off the power ribbon with a plastic card or a nylon spudger.
      FixBot'a Sor
      Yorum Ekle
    6. LG G6 Motherboard Replacement: adım 10, 3 resimden 1. LG G6 Motherboard Replacement: adım 10, 3 resimden 2. LG G6 Motherboard Replacement: adım 10, 3 resimden 3.
      • Firmly pull the blue tab. Be careful not to bend the battery as you pull it away from the adhesive.
      • Do not use a knife as you may pierce the battery.
      FixBot'a Sor
      Yorum Ekle
    1. LG G6 Motherboard Replacement, Motherboard: adım 11, 2 resimden 1. LG G6 Motherboard Replacement, Motherboard: adım 11, 2 resimden 2.
      • Locate the sim card tray release mechanism on the right edge.
      • Using the tweezers, or similar thin and rigid tool, push in the release button and pull out the sim card tray.
      FixBot'a Sor
      Yorum Ekle
    2. LG G6 Motherboard Replacement: adım 12, 3 resimden 1. LG G6 Motherboard Replacement: adım 12, 3 resimden 2. LG G6 Motherboard Replacement: adım 12, 3 resimden 3.
      • Gently pry off the two connectors at the bottom of the phone.
      • Pry off the tape covering the vibrator.
      FixBot'a Sor
      Yorum Ekle
    3. LG G6 Motherboard Replacement: adım 13, 2 resimden 1. LG G6 Motherboard Replacement: adım 13, 2 resimden 2.
      • The motherboard is now removable by gently lifting.
      • Upon removal of the motherboard, the small plastic sim card tray release mechanism will be loose and may get lost.
      FixBot'a Sor
      Yorum Ekle
Sonuç
4 farklı kişi bu kılavuzu tamamladı.
David Pugliese
1.156 İtibar
4 adet Kılavuz yazıldı
Ekip
USF Tampa, Team S2-G6, Passmore Fall 2017 USF Tampa, Team S2-G6, Passmore Fall 2017 üyesi
USFT-PASSMORE-F17S2G6
4 Üyeler
48 adet Kılavuz yazıldı
4Kılavuz Yorumları
Hi where i can find mainborad for lg g6 h870
Zaid Nashwan - Yanıt Paylaş
i found one on ebay
Greg - Yanıt Paylaş
How much access to the SIM Reader does this give you? A customer has broken his SIM Tray and there is a part stuck inside, will removing the board allow me to reach this or would I be removing it for no reason?
Any response appreciated, ty.
RDCharlton - Yanıt Paylaş
very good detail
Greg - Yanıt Paylaş
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 2
Son 7 gün: 8
Son 30 gün: 44
Her zaman: 8,115
