Ana içeriğe geç
LG G7 ThinQ Speaker System Replacement
Neye ihtiyacın var
  1. LG G7 ThinQ Speaker System Replacement, SIM Card: adım 1, 1 resimden 1.
    • Insert a SIM card eject tool into the hole in the SIM card slot on the top right of the phone.
    • After the SIM card tray is ejected, remove the SIM card tray from the phone.
    • Remove the SIM card from the tray.
  2. LG G7 ThinQ Speaker System Replacement, Back Cover: adım 2, 1 resimden 1.
    • Place the phone so the back cover is facing upwards.
    • Insert the opening picks one by one onto each side with equal pressure.
    • There is extra adhesive at the top near the cameras. You need to loosen the adhesive there to open the case.
    • If the picks are too thick to fit in, you can use the Jimmy to start the process.
    • Use the pick with the best leverage to pry the back cover away from the phone.
  3. LG G7 ThinQ Speaker System Replacement, Speaker System: adım 3, 1 resimden 1.
    • This device did not come with a midframe, but if yours does, follow the instructions in the teardown video to remove it.
    • Remove the screws along the perimeter and central area of the phone using a Phillips #000 screwdriver.
  4. LG G7 ThinQ Speaker System Replacement, Remove the speaker system: adım 4, 1 resimden 1.
    Bu adımda kullanılan alet:
    Satın Al
    • Use your fingers or tweezers to remove the speaker system.
Sonuç
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 3
Son 30 gün: 25
Her zaman: 812
