Ana içeriğe geç
LG G8 ThinQ Speaker System Replacement
Neye ihtiyacın var
  1. LG G8 ThinQ Speaker System Replacement, SIM Card Tray: adım 1, 3 resimden 1. LG G8 ThinQ Speaker System Replacement, SIM Card Tray: adım 1, 3 resimden 2. LG G8 ThinQ Speaker System Replacement, SIM Card Tray: adım 1, 3 resimden 3.
    • Unplug and power off your phone before you begin.
    • Insert the SIM card eject tool into the pinhole in the lower right side of the phone.
    • Remove the SIM card and tray.
  2. LG G8 ThinQ Speaker System Replacement, Back Panel: adım 2, 3 resimden 1. LG G8 ThinQ Speaker System Replacement, Back Panel: adım 2, 3 resimden 2. LG G8 ThinQ Speaker System Replacement, Back Panel: adım 2, 3 resimden 3.
    • Place the phone so that the screen is facing down.
    • Insert opening cards between the back panel and frame of the phone to loosen the clips and adhesive.
    • Using equal pressure, carefully pry the back panel away from the phone.
    • Once enough space has been created, use an opening tool to completely separate the back panel from the phone.
  3. LG G8 ThinQ Speaker System Replacement, Midframe: adım 3, 3 resimden 1. LG G8 ThinQ Speaker System Replacement, Midframe: adım 3, 3 resimden 2. LG G8 ThinQ Speaker System Replacement, Midframe: adım 3, 3 resimden 3.
    • Remove all 14 screws from the midframe using a Phillips #000 screwdriver.
    • Work an opening tool around the perimeter of the midframe to pry and remove it from the phone.
  4. LG G8 ThinQ Speaker System Replacement, Speaker System: adım 4, 3 resimden 1. LG G8 ThinQ Speaker System Replacement, Speaker System: adım 4, 3 resimden 2. LG G8 ThinQ Speaker System Replacement, Speaker System: adım 4, 3 resimden 3.
    • Using an opening tool, carefully pry out remove the speaker system from the phone.
Sonuç
Bir başkası bu kılavuzu tamamladı.
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 6
Son 30 gün: 22
Her zaman: 608
