Ana içeriğe geç
LG GS170 Battery Replacement
  1. LG GS170 Battery Replacement, Back Cover: adım 1, 3 resimden 1. LG GS170 Battery Replacement, Back Cover: adım 1, 3 resimden 2. LG GS170 Battery Replacement, Back Cover: adım 1, 3 resimden 3.
    • Turn off the the cell phone.
    • Locate the the arrow at the top of the back cover.
    • Slide the cover downward until the cover comes off.
  2. LG GS170 Battery Replacement, Battery: adım 2, 3 resimden 1. LG GS170 Battery Replacement, Battery: adım 2, 3 resimden 2. LG GS170 Battery Replacement, Battery: adım 2, 3 resimden 3.
    • Completely remove the back cover, and the battery should be visible.
    • Locate the gap at the bottom right.
    • Use your thumb to pop out the battery.
  3. LG GS170 Battery Replacement: adım 3, 1 resimden 1.
    • The battery can be easily removed once it's lose. The ID tag should be visible after the battery is removed.
    • Be careful of damaged battery. Inspect the battery for crack, rupture of the plastic, excessive leaking, or discoloration. Remove the battery carefully if it appears damaged.
Sonuç
Bir başkası bu kılavuzu tamamladı.
Minna
101 İtibar
1 Kılavuz yazıldı
Ekip
USF Tampa, Team 1-25, Donnelly Fall 2014 USF Tampa, Team 1-25, Donnelly Fall 2014 üyesi
USFT-DONNELLY-F14S1G25
1 Üye
2 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 3
Son 7 gün: 8
Son 30 gün: 16
Her zaman: 598
