Ana içeriğe geç
Giriş
This guide will assist you while you take your phone apart. This disassemble is not a very difficult task. There will be a few connectors that will be disconnected during the process. Make sure to be cautious with them so they do not rip. There are many little screw that will be taken off the phone. Make sure that you have a clean and organized work space.
  1. Remove the back cover by firmly pressing the triangle and push upwards. Lift the bottom section to remove the cover.
    • Remove the back cover by firmly pressing the triangle and push upwards.
    • Lift the bottom section to remove the cover.
  2. Remove the battery by lifting from the bottom. Remove the battery by lifting from the bottom.
    • Remove the battery by lifting from the bottom.
  3. Remove six 3mm PH000 screws.
    • Remove six 3mm PH000 screws.
  4. Peel off the sticker with the metal spudger. Remove one 1mm PH000 screw. Remove one 1mm PH000 screw.
    • Peel off the sticker with the metal spudger.
    • Remove one 1mm PH000 screw.
  5. Pry open all four sides of the back-frame gently, using the metal spudger.
    • Pry open all four sides of the back-frame gently, using the metal spudger.
    • The back-frame should come out easily.
    • Volume button and shutter button may fall out during the process.
  6. Pry off the connector using the iFixit opening tool to remove the communication board.
    • Pry off the connector using the iFixit opening tool to remove the communication board.
  7. Pry off the connectors using the iFixit opening tool. Disconnect the antenna using the iFixit opening tool. The motherboard should be able to be removed easily.
    • Pry off the connectors using the iFixit opening tool.
    • Disconnect the antenna using the iFixit opening tool.
    • The motherboard should be able to be removed easily.
Sonuç
Jonas Ke
468 İtibar
3 adet Kılavuz yazıldı
Takım
IUPUI, Team S1-G6, Hovde Fall 2018 IUPUI, Team S1-G6, Hovde Fall 2018 üyesi
IUPUI-HOVDE-F18S1G6
3 Üyeler
0 Yorum
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 Gün: 0
Son 30 Gün: 0
Her zaman: 42
