Ana içeriğe geç
LG GizmoGadget VC200 Battery Replacement
  1. LG GizmoGadget VC200 Battery Replacement, Battery: adım 1, 1 resimden 1.
    • Pick any sides, and just wedge a flat pick to pop it open. Its held by gasket. I choose the top. work out well for me
  2. LG GizmoGadget VC200 Battery Replacement: adım 2, 1 resimden 1.
    • Try to keep some of the gaskets on the right, some will be tangle up, you can cut those out. The pin connectors on the left, they are not glue down so if you drop them, just put them back
  3. LG GizmoGadget VC200 Battery Replacement: adım 3, 1 resimden 1.
    • Use the pull tab to pull out the battery.. if it doesn't pull out, wedge something under it.. the one I had was pretty weak, pulled out easier.
  4. LG GizmoGadget VC200 Battery Replacement: adım 4, 1 resimden 1.
    • Battery is out.
  5. LG GizmoGadget VC200 Battery Replacement: adım 5, 1 resimden 1.
    • New vs old. Just bend the new battery connector similar to the old battery
  6. LG GizmoGadget VC200 Battery Replacement: adım 6, 1 resimden 1.
    • From the old connector, transfer the double side tape and put it into the new battery
  7. LG GizmoGadget VC200 Battery Replacement: adım 7, 1 resimden 1.
    • Place the new battery in and match the battery pigtail to the watch case. There are 2 dimples where you match to the pig tale. Once all the parts are secure, just snap the face back and do a test. Make sure everything still works, calling, texting, touch screen.
  8. LG GizmoGadget VC200 Battery Replacement: adım 8, 1 resimden 1.
    • BL-S5 is the battery part number
Sonuç
mikebuy78
157 İtibar
1 Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 0
Son 7 gün: 2
Son 30 gün: 21
Her zaman: 2,291
