Ana içeriğe geç
LG Incite Back Panel Replacement
Neye ihtiyacın var
  1. LG Incite Back Panel Replacement, Battery: adım 1, 1 resimden 1.
    • Hold the phone camera-side up and locate the rear cover.
    FixBot'a Sor
    Yorum Ekle
  2. LG Incite Back Panel Replacement: adım 2, 1 resimden 1.
    • Place a thumb below the camera, apply a little pressure, and slide the cover toward the bottom of the phone.
    FixBot'a Sor
    Yorum Ekle
  3. LG Incite Back Panel Replacement: adım 3, 1 resimden 1.
    • Place the plastic opening tool in the small slot below and to the left of the battery.
    • Pry the battery upward to remove it.
    FixBot'a Sor
    Yorum Ekle
  4. LG Incite Back Panel Replacement, Back Panel: adım 4, 1 resimden 1.
    • Using the #00 Philips screw driver, unscrew the four 4.5mm screws located around the battery compartment.
    FixBot'a Sor
    Yorum Ekle
  5. LG Incite Back Panel Replacement: adım 5, 1 resimden 1.
    • Wedge the plastic opening tool between the screen and the body of the device, using care to avoid damaging internal components.
    • Gently move the tool around the perimeter of the screen to separate it from the body.
    • You should not completely separate the screen from the device in this step.
    FixBot'a Sor
    Yorum Ekle
  6. LG Incite Back Panel Replacement: adım 6, 1 resimden 1.
    • Flip the device over so the battery compartment faces up.
    • Press the scroll wheel, located in the upper-left corner, into the device to avoid damage.
    • Gently insert the plastic opening tool into the seam between the frame and front cover to separate the back panel from the device.
    • The volume, lock, and camera buttons are loose, so be careful not to misplace them.
    FixBot'a Sor
    Yorum Ekle
Sonuç
Kimberly Kha
163 İtibar
5 adet Kılavuz yazıldı
Ekip
Cal Poly, Team 2-18, Maness Spring 2013 Cal Poly, Team 2-18, Maness Spring 2013 üyesi
CPSU-MANESS-S13S2G18
4 Üyeler
17 adet Kılavuz yazıldı
0Kılavuz Yorumları
Yorum Ekle
İstatistikleri Görüntüle:
Son 24 Saat: 1
Son 7 gün: 4
Son 30 gün: 27
Her zaman: 1,022
